WD Linux not compatible with Ultimeter 2100
Hi!
I’ve set up a Ultimeter 2100 station, it works perfectly with WD when set up with datalogger output and long message format in WD under Windows.
However I would prefer Linux, and it does not work under Linux with the same settings. It does not receive data from the Ultimeter at all. If I change the Ultimeter to run in complete record mode output from the Ultimeter WD does log some data, but it’s incomplete and values are incorrect.
Anyone tried this combination and made it work?
I would prefer Linux as it’s easier to run headless. Tested under Debian/Ubuntu
