cloudy
Author Topic: HDR (High Dynamic Range) Photography  (Read 13839 times)
Offline N7XSQ
  • Phoenix, Arizona
« on: May 21, 2007, 11:59:38 PM »
If you are not already familiar with HDR (High Dynamic Range) photography, you might want to look at the references below. I just discovered this recently, and I'm thinking this technique would would be very useful for storm images.
It basically involves creating a floating point representation of the scene from a bracketed set of shots.This representation contains a much greater dynamic range than can be represented in any one conventional digital image. Mapping techniques are then used to produce a viewable image that contains more detail across a wider range of illumination than can be captured in a single exposure. This technique can also be used to manipulate the image to look almost surreal, so that you can't quite tell if it is real or not.
http://www.hdrsoft.com/examples.html - STUNNING examples
http://www.hdrsoft.com/images/more_examples/tm.html - more realistic type examples from the same place. Look at the one at the bottom!
http://tutorialblog.org/hdr-tutorials-roundup/ - Tutorials & more examples. Look at 6th and 9th images. Others are more artistic and less realistic.
http://www.17things.com/hdr-photos/ Some more examples, even more artistic.
http://www.hdrsoft.com/index.html - PhotoMatrix software for doing this ~US$100
Steve
« Last Edit: May 22, 2007, 12:03:28 AM by N7XSQ »
Offline Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
Re: HDR (High Dynamic Range) Photography
« Reply #1 on: May 22, 2007, 09:21:38 AM »
Nice one Steve,
I wonder if you could get away with playing with the RAW images before converting to jpg and then Photoshop them together, adjusting the transparancy in some areas of the photo, to give the same effects?
May have a play later.  :D
Offline amarilloweather
  • Amarillo, Texas, USA
    • AmarilloWeather
« Reply #2 on: May 22, 2007, 01:14:56 PM »
Those are some incredible images!  I'd like to try that with some of my lightning photography.
Thanks for sharing.
Corey
Offline administrator
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« Reply #3 on: May 25, 2007, 11:05:49 AM »
Something else to spend some time trying! I wonder if my digital camera can do bracketing or will I finally need to make the jump to DSLR?
Chris
Weather Forum Administrator
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #4 on: May 25, 2007, 01:19:59 PM »
If you were an SLR user back in the days of film, then you'll really appreciate the upgrade to from a D to a DSLR. You can always bracket manually if it's static scene (and you have manual control), but autobracketing is very cool.
Offline N7XSQ
  • Phoenix, Arizona
« Reply #5 on: May 25, 2007, 04:13:05 PM »
Many of the non-entry level, but not DSLR, models will auto-bracket.
It is, after all, just some software to make it do that,
so it does not cost the camera maker extra to add it.
If you do get a new camera, especially if you want to use it for HDR,
you should consider one that has RAW output.
You can't do true HDR with moving subjects, like the dancers,
but you can do pseudo-HDR by taking one RAW image
and extracting three jpegs from it at different virtual exposure values.
Steve
Offline daveq
  • Hollywood, MD
« Reply #6 on: May 25, 2007, 04:50:01 PM »
Olympus makes several DSLR models that auto-bracket both exposure and white balance but only +/- 1ev max during 3 exposures.
--Dave
Offline Budgie
  • Martin
  • Global Moderator
    • Hebrides-Weather
« Reply #7 on: May 25, 2007, 05:08:23 PM »
If you can afford it (after all the problems you've been having with your PC's Chris) then I can highly recommend the Canon EOS 400D.
It will produce RAW images in the manual modes and the software that comes with it will allow you to play with RAW to give better quality effects for the likes of HDR than you will get after the image has been converted to jpg. You can set it to produce RAW & jpg if you want and it will store each image in both formats.
The cheapest place I found in the UK for the camera was Amazon and being an EOS then extra lenses aren't really a problem either as they are available second hand.
My first attempts with the camera at photographing the Northern Lights:
Offline niko
  • syzygy
  • Global Moderator
« Reply #8 on: May 25, 2007, 05:23:19 PM »
That's the Rebel XTi here, successor to the Rebel XT/350D that I have, it's a great camera.
Offline Budgie
  • Martin
  • Global Moderator
    • Hebrides-Weather
« Reply #9 on: May 25, 2007, 05:30:54 PM »
That's the one. We can still get the 350D new over here but it's only £70 less than the 400D so you may as well get the newer model.
I've still got to play with a lot of the features on it but have had very good results to date and the addition of the remote shutter is a must for the night shots.
That reminds me, there is good aurora activity at the moment so better get the battery topped up for tonight!!  :D
Offline niko
  • syzygy
  • Global Moderator
« Reply #10 on: May 25, 2007, 05:37:10 PM »
I'm not sure I care too much about the extra pixels, but I would definitely pay the extra for the self cleaning sensor system.
If you are handy you can make you own remote for a few $.
    • AmarilloWeather
« Reply #11 on: May 25, 2007, 06:26:54 PM »
Canon AE-1 for-the-win!   Wait....... nevermind.    :lol:
Corey
Offline Budgie
  • Martin
  • Global Moderator
    • Hebrides-Weather
« Reply #12 on: May 25, 2007, 06:48:17 PM »
Corey
Nothing wrong with that, I used my Pentax P30T for the night shots, until I got the EOS 400D.
It must be around 25 years old now and still produces good quality photos, plus I have lenses upto 500mm (1000mm if I add the 2x converter) for it. If only I could find a Pentax K to EOS converter! :D
Offline Clanger
  • This post best viewed on a computer
  • UK
« Reply #13 on: May 25, 2007, 06:50:13 PM »
Digital Cameras must  be one of the best inventions ever. I was in a camera shop last week and the guy let me have a go with the EOS 400D. Its very light and small for an SLR. Every shop or place you go everyone seems to recommend this camera. By the time I have saved up the next model will be out  :roll:
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« Reply #14 on: May 25, 2007, 07:24:56 PM »
I know a lot of people like the Canon range. However, I've got a very nice Minolta Dynax/Maxuum 800si with a decent set of lenses, so I'm torn between going for the Sony Alpha A100 which would allow me to re-use some of the lenses until I can replace them with an equivalent set of 'digital' lenses, and going for a brand change. The problem is that if I go for a brand change, I'm effectively writing off my Minolta kit because being film based I'd probably have to pay someone to take it away. There's a fair bit of money sunk into the film kit so it doesn't feel right to sell it off dirt cheap.
Chris
