Yeah thats what i failed to do, (removing the bottom ridge) I will make a new one
sometime, more than likely next year as its not to the standard that i would prefer,
i.e. the spacers aint the best
Also the top saucer is a bit of a mess. I also want to make apoint on the top saucer
as even though its now flat'ish water still accumulates on the top...
Any ideas for the point as it will be a little difficult due to the bracket mounting...
I do have a slightly unrelated question...
On the Davis, when the full setup is all mounted in the 1 place on the mounting pole
I have noticed that the Black rain bucket is directly above the FARS, wouldnt this
attract heat and give false readings? It just seems to defeat the object having the
FARS white and a heat magnet above it?
