Hi peeps
After three days its finished (apart from the fan, will be added when it arrives)
I still think that when the fan arrives and i start to fit it, i may need to add another
saucer due to the height of my sensor, I also had to lay the sensor on its side due
to fitting issues but its in there with plenty of space around it. (WMR928NX sensor)
Also as the bottoms of my saucers are concaved and water would sit in there, i had
to find a quick way to fill it (i wanted to get it finished today) I used candle wax, I
heated it up in a tin on the gas hob, once melted to a consistency like water i just
poured it on the saucer bottom and let it cool, then finished off the paint that i had
left.
Ok granted it dont look the best but i thought that after 2 days of trying to fill the lips
i had best do something about the lid lol
As for the bracket its strong but thin, so the RS sways a little in a good wind, I may
stabilize it when i get round to actually sorting a more permanent spot for siting the
sensors.
An important note for anyone wishing to give this a goGood preparation will improve the fitting of the parts and the end product.
I thought i did a good job on the preparation but when it came to painting i was so wrong.
Make sure you use a flexible filler, Sand (no less than 800 grit) all the saucers to a smooth
finish, I would highly recommend a flexi bond as the base coat, this helps the adhesion of
the primer (i forgot and when i caught 1 of the saucers it peeled a little)
I may even do it again next year and try to get it a little tidier next time lol
Thanks Breitling for idea and walk through that made it all possible
