I even tried sealing the solar panel and thats didnt work out too well, thats
why i gave up with it!!
What I did, and what seems to be okay so far was to get a small piece of glass, say about 1cm bigger than the panel all round (e.g. from an old photo frame), place the panel upside down on the glass, then run a bead of silicone around the panel to attach the two together.
Then I attached the wires and put vaseline on the terminals (I'm worried about the acetic acid(?) fumes released during curing of the silicone causing tarnishing of the contacts).
Then I placed the glass with its attached panel on a similar sized piece of wood - with the panel as the middle layer, and then sealed all round with silicone.
That would probably be enough, but I then 'tidied' up with a layer of duct tape around the edges too,
So far that arrangement has stood up to some pretty wet weather.
