Dew Point jpGraph
This is what I use
<?php
//where are your clientraw*-files relative to where this file is
$hostloc = "../../";
include ("jp/src/jpgraph.php");//maybe you have to change this path
include ("jp/src/jpgraph_line.php");//maybe you have to change this path
//you dont have to change anything below this
// Create the graph and specify the scale for both Y-axis
$graph = new Graph(400,250,"auto",30);
$graph->SetScale("textlin");
$graph->SetY2Scale("lin",0,100);
$graph->SetShadow();
$graph->SetMarginColor("blue");
$graph->img->SetAntiAliasing();
//$clientraw = get_raw("${hostloc}clientraw.txt");
$clientrawextra = get_raw("${hostloc}clientrawextra.txt");
//$clientrawdaily = get_raw ("${hostloc}clientrawdaily.txt");
//read the clientraw*-files we need
function get_raw( $rawfile ) {
$rawdata = array();
$fd = fopen($rawfile, "r");
if ($fd) {
$rawcontents = '';
while (! feof ($fd) ) {
$rawcontents .= fread($fd, 8192);
fclose($fd);
$delimiter = " ";
$rawdata = explode ($delimiter, $rawcontents);
} else {
$rawdata[0]= -9999;
return $rawdata;
//temp=========================================================================
$y=array($clientrawextra['21'],$clientrawextra['22'],$clientrawextra['23'],$clientrawextra['24'],
$clientrawextra['25'],$clientrawextra['26'],$clientrawextra['27'],$clientrawextra['28'],$clientrawextra['29'],
$clientrawextra['30'],$clientrawextra['31'],$clientrawextra['32'],$clientrawextra['33'],$clientrawextra['34'],
$clientrawextra['35'],$clientrawextra['36'],$clientrawextra['37'],$clientrawextra['38'],$clientrawextra['39'],
$clientrawextra['40'],$clientrawextra['566'],$clientrawextra['567'],$clientrawextra['568'],$clientrawextra['569']);
array_walk($y,'CtoF');
$ydata = $y;
//hum=============================================================================
$y=array($clientrawextra['611'],$clientrawextra['612'],$clientrawextra['613'],$clientrawextra['614'],
$clientrawextra['615'],$clientrawextra['616'],$clientrawextra['617'],$clientrawextra['618'],$clientrawextra['619'],
$clientrawextra['620'],$clientrawextra['621'],$clientrawextra['622'],$clientrawextra['623'],$clientrawextra['624'],
$clientrawextra['625'],$clientrawextra['626'],$clientrawextra['627'],$clientrawextra['628'],$clientrawextra['629'],
$clientrawextra['630'],$clientrawextra['631'],$clientrawextra['632'],$clientrawextra['633'],$clientrawextra['634']);
$y2data = $y;
$Tc[1] = $clientrawextra[21];
$Tc[2] = $clientrawextra[22];
$Tc[3] = $clientrawextra[23];
$Tc[4] = $clientrawextra[24];
$Tc[5] = $clientrawextra[25];
$Tc[6] = $clientrawextra[26];
$Tc[7] = $clientrawextra[27];
$Tc[8] = $clientrawextra[28];
$Tc[9] = $clientrawextra[29];
$Tc[10] = $clientrawextra[30];
$Tc[11] = $clientrawextra[31];
$Tc[12] = $clientrawextra[32];
$Tc[13] = $clientrawextra[33];
$Tc[14] = $clientrawextra[34];
$Tc[15] = $clientrawextra[35];
$Tc[16] = $clientrawextra[36];
$Tc[17] = $clientrawextra[37];
$Tc[18] = $clientrawextra[38];
$Tc[19] = $clientrawextra[39];
$Tc[20] = $clientrawextra[40];
$Tc[21] = $clientrawextra[566];
$Tc[22] = $clientrawextra[567];
$Tc[23] = $clientrawextra[568];
$Tc[24] = $clientrawextra[569];
$RH[1]= $clientrawextra[611];
$RH[2]= $clientrawextra[612];
$RH[3]= $clientrawextra[613];
$RH[4]= $clientrawextra[614];
$RH[5]= $clientrawextra[615];
$RH[6]= $clientrawextra[616];
$RH[7]= $clientrawextra[617];
$RH[8]= $clientrawextra[618];
$RH[9]= $clientrawextra[619];
$RH[10]= $clientrawextra[620];
$RH[11]= $clientrawextra[621];
$RH[12]= $clientrawextra[622];
$RH[13]= $clientrawextra[623];
$RH[14]= $clientrawextra[624];
$RH[15]= $clientrawextra[625];
$RH[16]= $clientrawextra[626];
$RH[17]= $clientrawextra[627];
$RH[18]= $clientrawextra[628];
$RH[19]= $clientrawextra[629];
$RH[20]= $clientrawextra[630];
$RH[21]= $clientrawextra[631];
$RH[22]= $clientrawextra[631];
$RH[23]= $clientrawextra[633];
$RH[24]= $clientrawextra[634];
//dew array in degrees F
$dewF = array();
for ($i = 1;$i < 25;$i++)
$dewF = array_merge($dewF,array(DEWF($Tc[$i],$RH[$i])));
//dew array in Celcius
$dewC = array();
$dewC = array_merge($dewC,array(DEWC($Tc[$i],$RH[$i])));
//function
// Calculate dewF
function DEWF($Tc,$RH) {
         $Es=6.11*pow(10.0,(7.5*$Tc/(237.7+$Tc)));
         $E=($RH*$Es)/100;
         $Tdc=(-430.22+237.7*log($E))/(-log($E)+19.08);
         $Tdc= sprintf ("%01.1f", $Tdc);
		$Tdf = 1.8*$Tdc+32;
  return $Tdf;
} // end function calculate dewF
// Calculate dewC
function DEWC($Tc,$RH) {
         $E=($RH*$Es)/100;
  return $Tdc;
} // end function calculate dewC
// CtoF: converts degrees Celcius to degrees F
function CtoF(&$value) {
  return round($value = ((1.8* $value) + 32),1);
} // end function C_to_F
//create timearray for the x-axis
$n=1;
$limit=24;
$time=date(" H",time());
$datat=array($time);
$x=$datat;
//what you have to add
$add=3600;
$result=strtotime($time);
for ($n=1;$n++;)
$result=($result-$add);
$new=date('ga', $result);
$next=array("$new");
$datat= array_merge ($next,$datat);
if ($n>=$limit) break;
$datat=array_merge($datat,$x);
// From here we start creating the graphs
// Box around plotarea
$graph->SetBox();
// No frame around the image
$graph->SetFrame(false);
// Setup the tab title
$graph->tabtitle->Set('Temperature, Dew & Humidity');
$graph->tabtitle->SetFont(FF_FONT1,FS_BOLD,10);
$graph->tabtitle->SetColor('navy','lightyellow','navy');
// Adjust the margin
$graph->img->SetMargin(55,40,25,55);
// Create the 3 linear plot
$lineplot=new LinePlot($ydata);
$lineplot2=new LinePlot($y2data);
$lineplot3=new LinePlot($dewF);
// Add the plot to the graph
$graph->Add($lineplot);
$graph->Add($lineplot3);
$graph->AddY2($lineplot2);
$lineplot2->SetWeight(2);
//x-axis
$graph->xaxis->title->Set(date("M j"));
$graph->xaxis->SetTickLabels($datat);
$graph->xaxis->SetTextLabelInterval(2);
$graph->xaxis->HideTicks(true,true);
$graph->xaxis->SetPos("min");
$graph->xgrid->Show(true);
//y-axis
$graph->yaxis->title->SetFont(FF_FONT1);
$graph->yaxis->SetColor("red");
$graph->yaxis->SetLabelFormat('%0.0f
