Author Topic: Dew Point jpGraph  (Read 2803 times)
Offline daveq
  • Hollywood, MD
Dew Point jpGraph
« on: March 10, 2007, 07:28:21 PM »
I've been studying the different jpGraphs that others have developed.  I was thinking of trying to develop one either included into the temp/humidity or separate.  Kinda figured what the different parts of the code do but when I went to look for the clientrawextra fields for dew point I found there are none.
Anyone think dewpoint would be worthwhile or would it add too much to the clientrawextra if Brian were willing to include it?
--Dave
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
Re: Dew Point jpGraph
« Reply #1 on: March 10, 2007, 07:30:55 PM »
Dew point can be calculated from Temp and Humidity I think.
Offline TNETWeather
  • Mesa, AZ
« Reply #2 on: March 10, 2007, 07:57:48 PM »
Gives a rough idea of Dewpt.  Most likely close enough though.
Quote
I'm wondering if anyone could please give me the formula for the calculation of dewpoint temperature given relative humidity, current temperature, and station pressure
First calculate the saturation vap. pres. es (Pa) at temperature T (oC):
es = 610.78 * exp {A T / (T + B) }
where es in Pa, A = 17.2694 and B = 237.3 for T>0 otherwise 265.5.
Then calculate the actual vapour pressure e (Pa) using
e = rH / 100 * es
where rH is the rel.hum in %. Finally invert the equation for es since e = es(Td). The dewpoint temperature Td (oC) is then obtained from
Td = B  f / { 1 - f  }
where
f = ln ( e / 610.78 ) / A
(Based on Monteith and Unsworth, 1990, Principles of Environmental Physics, sec.ed., Arnold, London, 291pp.  ISBN 0-7131-2931-X. Note however that their equation 2.25 for Td is wrong) N.J. Bink
Offline pinto
  • Belgium
    • weather station Kampenhout
« Reply #3 on: March 10, 2007, 08:19:46 PM »
This is what I use
Code: [Select]
<?php
//where are your clientraw*-files relative to where this file is
$hostloc "../../";
include (
"jp/src/jpgraph.php");//maybe you have to change this path
include ("jp/src/jpgraph_line.php");//maybe you have to change this path
//you dont have to change anything below this
// Create the graph and specify the scale for both Y-axis
$graph = new Graph(400,250,"auto",30);
$graph->SetScale("textlin");
$graph->SetY2Scale("lin",0,100);
$graph->SetShadow();
$graph->SetMarginColor("blue");
$graph->img->SetAntiAliasing();
//$clientraw = get_raw("${hostloc}clientraw.txt");
$clientrawextra get_raw("${hostloc}clientrawextra.txt");
//$clientrawdaily = get_raw ("${hostloc}clientrawdaily.txt");
//read the clientraw*-files we need
function get_raw$rawfile ) {
$rawdata = array();
$fd fopen($rawfile"r");
if (
$fd) {
$rawcontents '';
while (!
feof ($fd) ) {
$rawcontents .= fread($fd8192);
fclose($fd);
$delimiter " ";
$rawdata explode ($delimiter$rawcontents);
} else {
$rawdata[0]= -9999;
return
$rawdata;
//temp=========================================================================
$y=array($clientrawextra['21'],$clientrawextra['22'],$clientrawextra['23'],$clientrawextra['24'],
$clientrawextra['25'],$clientrawextra['26'],$clientrawextra['27'],$clientrawextra['28'],$clientrawextra['29'],
$clientrawextra['30'],$clientrawextra['31'],$clientrawextra['32'],$clientrawextra['33'],$clientrawextra['34'],
$clientrawextra['35'],$clientrawextra['36'],$clientrawextra['37'],$clientrawextra['38'],$clientrawextra['39'],
$clientrawextra['40'],$clientrawextra['566'],$clientrawextra['567'],$clientrawextra['568'],$clientrawextra['569']);
array_walk($y,'CtoF');
$ydata $y;
//hum=============================================================================
$y=array($clientrawextra['611'],$clientrawextra['612'],$clientrawextra['613'],$clientrawextra['614'],
$clientrawextra['615'],$clientrawextra['616'],$clientrawextra['617'],$clientrawextra['618'],$clientrawextra['619'],
$clientrawextra['620'],$clientrawextra['621'],$clientrawextra['622'],$clientrawextra['623'],$clientrawextra['624'],
$clientrawextra['625'],$clientrawextra['626'],$clientrawextra['627'],$clientrawextra['628'],$clientrawextra['629'],
$clientrawextra['630'],$clientrawextra['631'],$clientrawextra['632'],$clientrawextra['633'],$clientrawextra['634']);
$y2data $y;
$Tc[1] = $clientrawextra[21];
$Tc[2] = $clientrawextra[22];
$Tc[3] = $clientrawextra[23];
$Tc[4] = $clientrawextra[24];
$Tc[5] = $clientrawextra[25];
$Tc[6] = $clientrawextra[26];
$Tc[7] = $clientrawextra[27];
$Tc[8] = $clientrawextra[28];
$Tc[9] = $clientrawextra[29];
$Tc[10] = $clientrawextra[30];
$Tc[11] = $clientrawextra[31];
$Tc[12] = $clientrawextra[32];
$Tc[13] = $clientrawextra[33];
$Tc[14] = $clientrawextra[34];
$Tc[15] = $clientrawextra[35];
$Tc[16] = $clientrawextra[36];
$Tc[17] = $clientrawextra[37];
$Tc[18] = $clientrawextra[38];
$Tc[19] = $clientrawextra[39];
$Tc[20] = $clientrawextra[40];
$Tc[21] = $clientrawextra[566];
$Tc[22] = $clientrawextra[567];
$Tc[23] = $clientrawextra[568];
$Tc[24] = $clientrawextra[569];
$RH[1]= $clientrawextra[611];
$RH[2]= $clientrawextra[612];
$RH[3]= $clientrawextra[613];
$RH[4]= $clientrawextra[614];
$RH[5]= $clientrawextra[615];
$RH[6]= $clientrawextra[616];
$RH[7]= $clientrawextra[617];
$RH[8]= $clientrawextra[618];
$RH[9]= $clientrawextra[619];
$RH[10]= $clientrawextra[620];
$RH[11]= $clientrawextra[621];
$RH[12]= $clientrawextra[622];
$RH[13]= $clientrawextra[623];
$RH[14]= $clientrawextra[624];
$RH[15]= $clientrawextra[625];
$RH[16]= $clientrawextra[626];
$RH[17]= $clientrawextra[627];
$RH[18]= $clientrawextra[628];
$RH[19]= $clientrawextra[629];
$RH[20]= $clientrawextra[630];
$RH[21]= $clientrawextra[631];
$RH[22]= $clientrawextra[631];
$RH[23]= $clientrawextra[633];
$RH[24]= $clientrawextra[634];
//dew array in degrees F
$dewF = array();
for (
$i 1;$i 25;$i++)
$dewF array_merge($dewF,array(DEWF($Tc[$i],$RH[$i])));
//dew array in Celcius
$dewC = array();
for (
$i 1;$i 25;$i++)
$dewC array_merge($dewC,array(DEWC($Tc[$i],$RH[$i])));
//function
// Calculate dewF
function DEWF($Tc,$RH) {
$Es=6.11*pow(10.0,(7.5*$Tc/(237.7+$Tc)));
$E=($RH*$Es)/100;
$Tdc=(-430.22+237.7*log($E))/(-log($E)+19.08);
$Tdcsprintf ("%01.1f"$Tdc);
$Tdf 1.8*$Tdc+32;
  return
$Tdf;
// end function calculate dewF
// Calculate dewC
function DEWC($Tc,$RH) {
$E=($RH*$Es)/100;
  return
$Tdc;
// end function calculate dewC
// CtoF: converts degrees Celcius to degrees F
function CtoF(&$value) {
  return
round($value = ((1.8$value) + 32),1);
// end function C_to_F
//create timearray for the x-axis
$n=1;
$limit=24;
$time=date(" H",time());
$datat=array($time);
$x=$datat;
//what you have to add
$add=3600;
$result=strtotime($time);
for (
$n=1;$n++;)
$result=($result-$add);
$new=date('ga'$result);
$next=array("$new");
$datatarray_merge ($next,$datat);
if (
$n>=$limit) break;
$datat=array_merge($datat,$x);
// From here we start creating the graphs
// Box around plotarea
$graph->SetBox();
// No frame around the image
$graph->SetFrame(false);
// Setup the tab title
$graph->tabtitle->Set('Temperature, Dew & Humidity');
$graph->tabtitle->SetFont(FF_FONT1,FS_BOLD,10);
$graph->tabtitle->SetColor('navy','lightyellow','navy');
// Adjust the margin
$graph->img->SetMargin(55,40,25,55);
// Create the 3 linear plot
$lineplot=new LinePlot($ydata);
$lineplot2=new LinePlot($y2data);
$lineplot3=new LinePlot($dewF);
// Add the plot to the graph
$graph->Add($lineplot);
$graph->Add($lineplot3);
$graph->AddY2($lineplot2);
$lineplot2->SetWeight(2);
//x-axis
$graph->xaxis->title->Set(date("M j"));
$graph->xaxis->SetTickLabels($datat);
$graph->xaxis->SetTextLabelInterval(2);
$graph->xaxis->HideTicks(true,true);
$graph->xaxis->SetPos("min");
$graph->xgrid->Show(true);
//y-axis
$graph->yaxis->title->SetFont(FF_FONT1);
$graph->yaxis->SetColor("red");
$graph->yaxis->SetLabelFormat('%0.0fF');
$graph->yaxis->HideTicks(true,true);
//y2-axis
$graph->y2axis->SetFont(FF_FONT1);
$graph->y2axis->scale->ticks->Set(20);
$graph->y2axis->SetColor("blue");
$graph->y2axis->SetLabelFormat('%0.0f%%');
$graph->y2axis->HideTicks(true,true);
$graph->y2grid->Show(true);
// Set the colors for the plots
$lineplot->SetColor("red");
$lineplot->SetWeight(2);
$lineplot2->SetColor("blue");
$lineplot2->SetFillColor("blue@0.7");
// Set the legends for the plots
$lineplot->SetLegend("Temperature");
$lineplot2->SetLegend("Humidity");
$lineplot3->SetLegend("Dew");
// Adjust the legend position
$graph->legend->SetLayout(LEGEND_HOR);
$graph->legend->Pos(0.5,0.9,"center","center");
$graph->legend->SetShadow('white',1);
$graph->legend->SetColor('black','white');
// Display the graph
$graph->Stroke();
« Last Edit: March 10, 2007, 08:46:50 PM by pinto »
Offline daveq
  • Hollywood, MD
« Reply #4 on: March 10, 2007, 09:51:30 PM »
Looks like you've done the hard work, Pinto.  You know I'll be sealing this, right? ;)
--Dave
« Last Edit: March 11, 2007, 07:56:02 PM by daveq »
Offline user3162
« Reply #5 on: March 11, 2007, 07:16:37 PM »
Thanks Pinto, this is something that I wanted,too!
