cloudy
Author Topic: Problem with NOAA forecasts  (Read 23758 times)
Offline Gregal
  • Greg
  • PA / USA
    • Allshouse_Weather
« on: February 13, 2007, 07:10:15 PM »
Is anyone seeing any problems today with the NOAA forecasts using crater lakes php querry today?  I went to the NOAA site and can not get to it for my location at thier site.
Re: Problem with NOAA forecasts
« Reply #1 on: February 13, 2007, 07:14:05 PM »
there are other threads on problems with the noaa server at the moment, yes
Offline Gregal
  • Greg
  • PA / USA
    • Allshouse_Weather
« Reply #2 on: February 13, 2007, 07:27:29 PM »
Thanks Brian.  Thought I was going crazy.  Or snow blind not sure which. :?
Greg
Offline snowman
  • C'Mon Snow
  • North Central Pa USA
    • sterlingrun.com
« Reply #3 on: February 13, 2007, 10:03:14 PM »
Having the same problem here I think...
Here is what my forecast page looks like:
http://weather.sterlingrun.com/wx2.php
Just to be sure, I retraced the steps to create this...went to the NOAA site, to my location, but do not see "Printable Forecast" anywhere on that page anymore - after re-reading the instructions from carterlake, it says to use the URL from the printable forecast..
Here is my NOAA page:
http://www.erh.noaa.gov/ctp/index.php
My forecast page has worked beautifully for a long time (and was working at 5am this morning), and I have not changed anything....but I know there have been quite a few issues lately with NOAA's site - and they are getting hammered right now due to the storm.
Offline carterlake
  • Tom Chaplin
  • Carter Lake, Iowa USA
    • Carter Lake, Iowa Weather
« Reply #4 on: February 13, 2007, 10:13:01 PM »
I've had that happen before... caused me quite a panic... but NOAA fixed it.
WD; Davis VP2 6153; Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; Live NOAA radio
abaldish
  • Guest
« Reply #5 on: February 13, 2007, 10:40:34 PM »
Looks like with the storm, they pulled alot of data from the stream, Here in pa the printable screen is also gone, and if you goto NOAA's site and look at others along the coast it is the same. as they pulled the plug on that part for now. So guess we have to wait and see.
Offline bboggess
  • Western NY
« Reply #6 on: February 14, 2007, 12:01:19 AM »
I was having intermittent problems starting yesterday afternoon.  Yesterday, the server that NOAA was using wasn't even pingable for a while.  Late afternoon, mine started to work again until early this morning.  Hasn't worked all day.  I also checked the server and the printable forecast was nowhere to be found, but, I could access the server it used to be located.  I manually put into a browser location box and noticed that the http string would redirect to an entirely different server and would pull up a "non printable" 7 day forecast.  Sure hope they get it fixed soon...
Bill
« Reply #7 on: February 14, 2007, 12:03:18 AM »
I would say its simply that the noaa server is overloaded, with everyone checking it, because of the severe and widespread winter weather pattern occuring, yes?
Offline BfdWx
  • Branford Connecticut
    • Branford Weather
« Reply #8 on: February 14, 2007, 12:23:11 AM »
Without a doubt, they took down parts of their site like the "printable forecasts" which messes up everybody.
mth
  • Guest
« Reply #9 on: February 14, 2007, 12:33:32 AM »
Mine down as well.....
mth
  • Guest
« Reply #10 on: February 14, 2007, 12:35:36 PM »
I went to my local NWS forecast page and they've removed the entire "printable forecast" links!!
Offline BfdWx
    • Branford Weather
« Reply #11 on: February 14, 2007, 12:57:33 PM »
On their "Forecast Discussion" page this morning.....
AREA FORECAST DISCUSSION...UPDATED
NATIONAL WEATHER SERVICE UPTON NY
610 AM EST WED FEB 14 2007
.EQUIPMENT...
ATTENTION ALL USERS...POINT AND CLICK FORECASTS ON THE NWS UPTON
WEBPAGE ARE NOT UPDATING AT THIS TIME. OUR REGIONAL HQ HAS BEEN
NOTIFIED AND WILL BE WORKING ON THE PROBLEM. THIS PROBLEM
APPEARS TO BE AFFECTING NEIGHBORING WFOS INCLUDING BOX/ALY/BGM/PHI
AT THIS TIME. USERS CAN FIND UPDATED WEATHER INFORMATION BY CLICKING
ON THE /LOCAL WEATHER/ LINK ON THE LEFT HAND SIDE OF THE MAIN WFO
UPTON HOMEPAGE...THEN SELECTING THE TEXT PRODUCT OF INTEREST. THE
LATEST ZONE FORECAST PRODUCT CAN BE FOUND BY SELECTING THE INDICATED
LINK BELOW THE POINT AND CLICK MAP.
abaldish
  • Guest
« Reply #12 on: February 14, 2007, 03:02:00 PM »
Here is what i have been seeing:
If you goto your NWS page for your area as for here it is http://www.erh.noaa.gov/ctp/ and you click on the map it redirects you to http://www.crh.noaa.gov/zones/PAZ024.php?zo=1 but of course it is not showing the city names only the counties. which is the Central Region Headquarters is where they have everone hitting.
Offline snowman
  • C'Mon Snow
    • sterlingrun.com
« Reply #13 on: February 15, 2007, 12:01:03 AM »
I have noticed a change in the use of the weather icons also - now the POP is listed underneath, where before the POP was part of the icon image....
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
« Reply #14 on: February 15, 2007, 12:12:17 AM »
Stan,
If you notice on the NWS site, when you type in your zip code (or city/state), it redirects you to the crh.noaa.gov site, rather than the erh.noaa.gov site.  This is probably the reason for the POP listed underneath.
--Tim
