Author Topic: WD and getting it on the web....correctly!?  (Read 3340 times)
warwickpaweather
  • Guest
« on: February 02, 2007, 05:36:21 PM »
1st of all thank you to Jozef for helping me thru most of this, but the problems seem to be getting deeper. I have the most current version of WD installed, as do I have the template pack from carterlake. The templates are in the WD folder and unzipped. The problem lies with me setting up the ftp in WD to send my files to my site.. www.warwickpaweather.net . I've read and re-read the read-me files, had help from Jozef and still nothing is correct. I think I need to start from the beginngin and wipe out all the ftp configurations. Any help would be appreciated..please email your guidance to me so I can print them and use them as the guide.
« Last Edit: February 02, 2007, 06:02:39 PM by warwickpaweather »
Offline pinto
  • Belgium
    • weather station Kampenhout
Re: WD and getting it on the web....correctly!?
« Reply #1 on: February 02, 2007, 05:42:18 PM »
I did mail this, but it did not work, can somebody please check I did not forget something in here ?
try to make 1 page work.
wxlocal.html is in your webfiles-folder of Weather Display on your home-computer
go to Weather Display
Hit "ControlPanel"
Hit Internet File Creation & Uploads
Go to 2nd tab (Setup page #2)
Hit the "Set" button next to "File #22 wxlocal.html"
Hit "Show file create times"
Hit the "Update every 15 mins" button
"Save now"-button
switch "Use this settings" must be turned on
"Show file upload times"
in FTP settings box you can put a name for the file (index.html)
in Remote directory do not enter anything
Hit"Same as file times"
Hit"Save now"
the button "Use these settings" must you turn to "On"
Hit"OK"
Hit"Override On"
Hit"OK"
Hit"OK"
Now you have to wait until Weather Display does the upload, you can see that in your system tray when a
red icon shows the letters WD
it must do the uploads on the hour,15 past, 30mins past and 45 mins past the hour
so the longest time you have to wait is 15 minutes before you can go and check your webpage
Online JaxWeather
  • Bob
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #2 on: February 02, 2007, 05:49:58 PM »
In Internet File Creation and Uploads after you have saved any changes always go back and make sure they stuck as at times it appears the creation or upload times don't stick the first time...
Offline Leo
  • Wellington,NZ.
    • http://homepages.paradise.net.nz/lfduflou/Silverstreamweather.htm
« Reply #3 on: February 02, 2007, 10:27:22 PM »
Under control panel/Ftp & Connections METAR NOAA FTP/connections tab
Is the main internet switch on?
If not turn switch on, click on save, then click on OK
XP ProSP2 AMD XP2600+ 1GB ram IE7 Beta3 Cable Modem Z/A Pro
http://www.kiwiweather.co.nz/whitbyweather/
XP ProSP2 AMD XP3200+ 1GB ram IE7 Beta3  DSL Z/A Pro
Offline pinto
  • Belgium
« Reply #4 on: February 03, 2007, 12:18:05 PM »
wx.html an so on are created fine when you look at them on the local harddisk
they are uploaded, but are chaged to some kind of garbage on FF2,IE makes them look like gifs
http://www.warwickpaweather.net/
warwickpaweather
  • Guest
« Reply #5 on: February 03, 2007, 01:03:58 PM »
Yeah not sure what to make of why they are changing or changed already.  The main internet switch is on, I do have 1 thought,,,,when I downloaded and unzpped carterlake's template pack, should it have been placed in the wd folder, the webfiles folder or just in the c drive?? and unzipped to...??? (I think that may be where my problem is---I might have done that incorrectly)...
Offline Stronghurst
  • Burgus Weather
  • Stronghurst,IL USA
    • Burgus Computers
« Reply #6 on: February 03, 2007, 01:22:17 PM »
The first file has to be "index.html"  On your web page it looks like it is wx2.html In the file creation page make sure that is the remote file name.  Also if you are using the Carter Lake template, make sure you upload the files that are a one time upload.
Mark
http://www.burgus.org
Every day is a good day.  Some days are just better than others.
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
    • Juneau County Weather
« Reply #7 on: February 03, 2007, 01:38:08 PM »
Mark is right, eventually you will want wx.html uploaded with the name index.html because that is what your isp will serve up as the default when someone hits your site.
That's not the big problem right now.  Your wx.htm through wx9.html files are ending up on the server with .gif  headers for some reason.  Perhaps unzip the files again, and they do go to the \wd\webfiles directory.  Does anyone else out there know what would cause these files to end up on the server with .gif headers?  Gotta be a simple answer somewhere.  - Jim
 Home of NSLog NexStorm Lightning Data Manager
Offline Stronghurst
  • Burgus Weather
    • Burgus Computers
« Reply #8 on: February 03, 2007, 02:03:05 PM »
webfiles folder
Mark
warwickpaweather
  • Guest
« Reply #9 on: February 03, 2007, 05:06:57 PM »
any one else having a problem such as this?? also, in WD, on the control panel-General Internet tab, should there be any files to the right in the files to upload area??
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
« Reply #10 on: February 03, 2007, 06:49:06 PM »
No, you don't need anything there.  That is for non-WD files.  - Jim
warwickpaweather
  • Guest
« Reply #11 on: February 04, 2007, 11:46:38 AM »
Can someone please check my site .   www.warwickpaweather.net and let me know  what COULD be the problem. Oh and by the way, displaying is the wxlocal page. the wx page had nothign but graphs on it from a week ago. I renamed the wxlocal as iindex.
Chris
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
« Reply #12 on: February 04, 2007, 12:49:12 PM »
You've got the same .gif issue going on for some reason.  This may take Brian's help to solve.  - Jim
warwickpaweather
  • Guest
« Reply #13 on: February 04, 2007, 01:04:49 PM »
Thanks Jim.....as an additional resource, I removed the index page to allow everyone the chance to look into my directory and see what is NOT NEEDED....I think maybe WD is sending files even with the upload option for each file type turned off.
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
« Reply #14 on: February 04, 2007, 01:22:12 PM »
I can see your wx.html file now as html, so something is starting to go right.  Make sure all your wxlocal*.html files are in the webfiles directory, then go back to Pintos post at the beginning of this thread and see if you can it uploading again.  - Jim
