cloudy
Author Topic: High-Resolution Weather Cam  (Read 111623 times)
Offline maltbie
Re: High-Resolution Weather Cam
« Reply #255 on: July 31, 2009, 11:39:25 PM »
Thanks to all of the great tips in this forum and specifically in this thread, I was inspired to get a digital camera to use as a webcam to share my view with the world.  It took me almost a month to figure out how to make it all work with WD/WDL, but the payoff is worth it.  Here are the results taken with a Canon A-520 hooked up to an old Dell C600 running Cam2Com uploading to www.westsandlakeweather.com:
Offline TokKiwi
  • Techno Dad
  • Mech Engineer and Hobbyist
  • Tokoroa, Sth Waikato, New Zealand
    • Tokoroa North Weather
« Reply #256 on: August 02, 2009, 02:31:46 AM »
Brilliant example.  You can use WD to capture it as a local file on a LAN and add some weather details overlay detail to it as well...
Dad's have hobbies because they are children's rugby, football and Committee Fathers!!
Offline choc-a-holic
  • Mahana, New Zealand
    • Mahana - NZ weather information
« Reply #257 on: September 21, 2009, 08:51:21 PM »
Overlay and weatherdata is plotted by a php-script called with a rewrite-rule in htaccess-file so when visitor call the .jpg it is resent to the php instead. ;)
Did you write the php-script yourself?  I would love to be able to have the photo date stamp on my webcam photos.  I did try using the utility provided in WD however there is a big degradation in photo quality which I was not happy with.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #258 on: September 21, 2009, 09:09:40 PM »
« Reply #259 on: September 26, 2009, 09:57:57 PM »
Try Mike's php image handler http://www.642weather.com/weather/scripts-image-handler.php
It looks good... I will give it a go.  Have you tried it with WDL?
Offline niko
  • syzygy
  • Global Moderator
« Reply #260 on: September 26, 2009, 10:20:54 PM »
No I haven't.
« Reply #261 on: October 12, 2009, 04:59:09 AM »
I just tried using Mike's PHP script, however it does not seem to work properly in WDL.  I didn't change much except, the location of the jpg and filename, and put some text in text1, 2, and 3 to see what happens.  I left everything else as default.  Has anyone else tried it?
