cloudy
Author Topic: Don't obfuscate (Leave Out) detail unless absolutely necessary  (Read 18570 times)
Online TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Global Moderator
  • Gremlins are at work...
  • Mesa, AZ
« on: December 23, 2006, 07:07:43 PM »
When asking questions about configurations, problems etc...  Try not to mask out detail from your logs, code, URL's etc.
There are often important clues to be found there, and what's irrelevant detail to you could be the key to the problem (this makes sense because if you knew what was important already, you probably could have solved the problem yourself).
Include URL's to your pages/sites/code, make sure you provide what version of WD the type of weather station equipment if you don't have it already in your profile, so that those that might be able to help can see all that is necessary to find the issue.  Many times, what you are looking at is not the area that is causing the problem in the first place.
« Last Edit: December 23, 2006, 07:14:25 PM by krelvinaz »
