I’ve done some more work to try to resolve the problems with incorrect passwords causing people to be locked out of the Bug Tracker. I’ve had to change the route into the Bug Tracker, so the link on the button at the top of the Forum page has changed to reflect that. If you access Bug Tracker using that link (whilst logged into the forum) then it should work OK. However, if you’ve created your own link or browser favourite to access the Bug Tracker you may find things still go wrong unless you change the link to use the new URL.
You should now use: http://wxd.weather-watch.com/mantis/login_page.php.
