in the WDL config file i have enabled the weather forecast, do i have to set up anything else? The thing is that i have lately noticed that it always says:
Forecast: Increasing clouds with little temp. change. Precipitation within 24 to 48 hours…
Under Control Panel - FTP - NOAA Forecast Download do you have “Use the Forecast for the VP Forecast system” ticked? If so unless you are downloading a NOAA forecast you would want that to be unticked…
Also note your WDL appears to be about 2 inches X 2 inches in size in FireFox and is unreadable…
