1 wire weather station not working
At present I run version 9.70d all okay apart from the pressure sensor which I know you are working on. I cannot seem to run versions from 9.71, even the latest stops working. The program starts & the clock stops & data flow stops while the pressure reading is taken, approx 30 sec. The clock then start okay wit the data. But the data stops around count 59, but the clock is okay. I waited to see if it was taking another reading but still nothing after 3 mins. The operating system is 98 8O :stuck_out_tongue:
someone is sending me a aag baro
but until i get it working correct,i.e once it arrives here, untick that option in the dallas setup
and restart
