cloudy
Author Topic: Webcam Software  (Read 5230 times)
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
Webcam Software
« on: November 11, 2006, 04:52:09 PM »
Hi guys...
I have been having some problems with the wdwebcapture.exe program (memory usage and commit time jumps randomly, causing the computer to freeze), so I am interested in purchasing a separate webcam software program.
I have downloaded the trial versions of ImageSalsa and WebcamXP.  I was sort of confused by the UI when using ImageSalsa, but like WebcamXP so far.  I saw that the price of WebcamXP was $40, which is the most I would like to spend.  Also, I was trying to get the streaming video on my website using WebcamXP, but had some problems.
Does anyone have any other suggestions?
--Tim
Re: Webcam Software
« Reply #1 on: November 11, 2006, 06:32:24 PM »
are you sure its wdwebcamcapture.exe causing your pc to freeze
i think this is the first report i have had of that
and what do you mean by commit time jumping randomly exactly?
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
Re: Webcam Software
« Reply #2 on: November 11, 2006, 07:49:45 PM »
Brian,
I am fairly sure that is what is causing the computer to freeze.
The commit charge will jump from the mid 500's to around 2000.
--Tim
Re: Webcam Software
« Reply #3 on: November 11, 2006, 08:39:43 PM »
instead of watching the commit charge, watch the memory use of the program via the processes tab
also check you dont have wdwebcamcapture.exe producing a video file that is getting bigger and bigger all time
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
Re: Webcam Software
« Reply #4 on: November 12, 2006, 03:32:26 AM »
Brian,
I did check the memory use of the program and noticed it at about 97,000 K.  Also, I know that wdwebcamcapture.exe was causing the high commit charge, as this happened once before, and after I ended it, the commit charge went back to normal.
--Tim
Re: Webcam Software
« Reply #5 on: November 12, 2006, 05:50:26 AM »
it should be only using about 13,000 k
there must be some settings that are conflicting or causing alot of memory, e,g avi movie file production....
you could try this...exit the wdwebcamcapture.exe
then run regedit.exe, and search for wdisplayftp.ini in the registry
then find the key, Web cam capture
and delete that whole key....to wipe clean the settings for the web cam
and then start from scratch
try that if you are interested
Offline weatheroz
  • Brendan
  • Logan Village, Queensland, Australia
    • Logan Village Weather
Re: Webcam Software
« Reply #6 on: November 12, 2006, 09:33:40 AM »
If you're going to spend the dollars, you'd be better going the ImageSalsa way. :)
I use it here for all my webcamera shots and weather 'stickers'.
Offline Geyserland Observatory
  • Rotorua - New Zealand
    • Geyserland Observatory  Rotorua / NZ
Re: Webcam Software
« Reply #7 on: November 12, 2006, 02:24:54 PM »
Have a look at:
http://www.webcamfirst.com/
is very good and free
you can see it on my website in action.
             Cheers, Rolf.
All the best, Rolf.
Astronomy, Atmosphere & Weather
http://www.geyserlandobservatory.org
Offline aifan27
  • Tim
  • Pennsylvania
    • Newtown Weather
Re: Webcam Software
« Reply #8 on: November 12, 2006, 03:33:30 PM »
Brendan,
How much is ImageSalsa?  Do you have to have VWS in order to place custom tags on the screen?  How is the UI?  As I said before, I found it quite confusing.
Thanks, Rolf.  I will take a look at it once it is light over there.  :wink:
--Tim
Re: Webcam Software
« Reply #9 on: November 12, 2006, 04:50:35 PM »
it used to be comptible with WD via the data.csv file you can set wd to create...
but i think the format of that has changed....if i knew what has changed, i can fix that...
Offline talbert1952
  • Tobaccoville, North Carolina USA
    • Tobaccoville Weather, Tobaccoville, NC USA
Re: Webcam Software
« Reply #10 on: November 12, 2006, 05:18:51 PM »
Ambient changed the data.csv file layout from V1.00 to V1.01 somewhere around 12.07 P56. The change broke all third party software using the file. Jason fixed Image Salsa but I can't remember if he left support for V1.00 in the product or not. His website shows he supports WD. If you haven't done so you might want to contact him at support@imagesalsa.com.
Tom
W4SNA
http://tobaccovilleweather.com/
Davis wireless VP2 with fan aspirated radiation shield, WMR968, Boltek Stormtracker PCI
Weatherlink, VWS, Image Salsa, Lightning/2000
Re: Webcam Software
« Reply #11 on: November 12, 2006, 05:23:29 PM »
thanks...i will send him email.....we have not swapped emails for a long time...
Aifan, also, please try that registry reset of the wd webcam capture settings, and start over with the settings, as I would be interested in seeing if you get it using much less memory and being stable again
Offline up10ad
  • Pardon my driving, I'm reloading.
  • Delta, CO USA
    • Delta, CO Weather
Re: Webcam Software
« Reply #12 on: November 12, 2006, 07:58:52 PM »
Like Oz, I use ImageSalsa for all my cam and sticker overlays, as well as a lot of other stuff.  I also make use of MovieSalsa, and my Toshiba Cam is featured on his MS demo page.  Like Brian and WD, Jason and IS/MS are well supported and worth every penny.
Rick
Have you joined USAWeatherFinder.com yet?
Offline weatheroz
  • Brendan
Re: Webcam Software
« Reply #13 on: November 12, 2006, 10:42:45 PM »
There's 3 versions of ImageSalsa, and the 'weather' version is the one you'd need to go for, which is $US49.95 whilst it does cost you money, it is money well spent.
I also bought MovieSalsa for $US19.95 so that I could take all my webcam images and produce a 'movie' of them all.
As far as the tags are concerned, WD can produce a data2.csv file, which you point ImageSalsa at and it reads them all quite happily, so you do not need to be running vws :) to utilise ImageSalsa.
ImageSalsa was probably the last thing that kept me running vws for as long as I did, as I didn't think it would work with WD, but later on found out that it works great with WD. :)
Offline weatheroz
  • Brendan
Re: Webcam Software
« Reply #14 on: November 12, 2006, 10:47:10 PM »
Unfortunately, when a certain clown blocks a full Class 'C' range of IP's, it prevents you from viewing the ImageSalsa support forums on the 'ambient' support site, but whilst I providing dozens of helpful posts for the vws people in there, Jason provided wonderful support and help with his product.
