Author Topic: Davis WM II  (Read 2029 times)
Offline Off Track
  • Joseph Oregon USA
    • Joseph Oregon Weather
Davis WM II
« on: November 02, 2006, 03:26:38 PM »
The last few times I had to shut down the computer for a bit WD would not pull in the data from the logger.
I was shut down for 20 min one time and it did get 2 lines of data but that was it. Not sure if its a new bug or my old data logger is showing its age.
Running 10.36R and the Davis WMII
Scott
http://www.josephoregonweather.com
Davis WM II, Heated rain collector
Dell E521, AMD Atholn 64 X2 Dual Core
Processor 3800+ 2.0 Ghz, 4 MB Ram
Win XP
Offline hydrowx
  • Bill
  • Northeast Illinois USA
    • Goose Lake Weather
Re: Davis WM II
« Reply #1 on: November 02, 2006, 04:09:56 PM »
Hi Scott...my WD had crashed around 145am Wed morning but I didn't notice it until that afternoon. When I restarted WD it successfully downloaded the missing 12 hrs of data. Did you manually reset the time on your WMII console since the time change?
Bill
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
Re: Davis WM II
« Reply #2 on: November 02, 2006, 04:14:41 PM »
Mine is working fine, just tested it now. 10.36r and WMII. I bet for that hour change.
Offline Off Track
  • Joseph Oregon USA
Re: Davis WM II
« Reply #3 on: November 03, 2006, 03:32:18 AM »
Got the hour set before all this, must be just me.
Scott
Win XP
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
Re: Davis WM II
« Reply #4 on: November 03, 2006, 01:32:02 PM »
A question for you WMII owners: Do you have inside humidity working?  Mine doesn't. Console shows "----" all the time, WD shows a stuck 50% reading.
Is there any seviceable part inside console to bring my inside humidity back to life?
Offline Off Track
  • Joseph Oregon USA
Re: Davis WM II
« Reply #5 on: November 03, 2006, 01:41:19 PM »
The inside humidity is working for me. I just found my problem some how the data logger got locked up. even after clearing it it will pick up data from 5 days back. Going to try the software that came with it to reset it all and start new I hope. Its going to get hard for parts for us WMII folks soon due to Davis has stopped production of the WMII.
You might try reseting the console. Remove your back up battery and the min power wait one minute and then reapply the power and your backup battery. If its just a lockup that should do it. Also make sure you cycle all the data cable plugs when you have the power off just to ensure you have good contacts. I think that was or is one of my problems. This unit has been running for 10 years.
Hope that helps.
Scott
Win XP
Offline Off Track
  • Joseph Oregon USA
Re: Davis WM II
« Reply #6 on: November 03, 2006, 02:01:50 PM »
That was it the data logger got locked up, One thing I found is if the connections are not just right things happen to that data logger, I had one plug that was loose.
Thanks all for the help.
 :D
Scott
Win XP
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
Re: Davis WM II
« Reply #7 on: November 03, 2006, 04:08:00 PM »
Console reset with no success. so I have decided to open it and take a look inside....  I've found the humidity sensor, working erratically (but working) every time I touch on its soldered contacts. After a very short Google search I've found the component: http://www2.informatik.hu-berlin.de/~hochmuth/bvp/humidity.pdf. So I'm going now to my nearest electronic components store :)
I'll tell you about.
Offline hydrowx
  • Bill
Re: Davis WM II
« Reply #8 on: November 04, 2006, 01:00:55 AM »
 :D
Glad to hear that you got it sorted out. :)
Breitling...best of luck on getting the inside RH component replaced. Fortunately, I haven't had a problem with mine.
Bill
Offline Breitling
  • Luis
  • NW Spain
    • Meteo Aerolugo
Re: Davis WM II
« Reply #9 on: November 22, 2006, 08:28:28 PM »
I have replaced my WMII indoor RH component, taking care not to put too much heat on the circuitboard. Everything ok !! :)
This is the component, located just behind the Davis logo:
