remove those extra links (i.e the html code) from the webfiles folder file, datahtm3.txt
(double click that file and it will open in notepad.exe and delete those repeated lines of html code), and then save that file
next update of your webpage and it should be OK
Note that you can add or remove html code from the datahtm0.txt file
and even add WD custom tags to the datahtm0.txt or datahtm3.txt file (but set WD to use those, in the webfiles/web page setup)
