cloudy
Author Topic: How to calibrate a tipping rain gauge.  (Read 4699 times)
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
    • Newburgh Weather
« on: August 16, 2006, 10:24:28 PM »
I have a tipping rain gauge that has been in service for 7 years. What would be the proper way to check it and calibrate if I find it needs tweaking?
It's a 6"dia top, and I use inches.
Thanks!
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: How to calibrate a tipping rain gauge.
« Reply #1 on: August 16, 2006, 10:41:19 PM »
OK, so the opening is 6" diameter, that makes the area of the opening pi * (3)2 = 3.142 * 9 = 28.278 sq inches.
If one inch of rain falls then 28.278 cubic inches of water would pass through the gauge.
28.278 cubic inches = 15.7 fluid ounces (US) or 463.39 millilitres (ml).
So if you measure that amount of water and drip it very slowly through the gauge, it should register one inch of rain. For a more accurate result drip a multiple of that amount of water, 2 or 3 inches, but be careful not to exceed the maximum rain rate that the gauge can handle.
Offline looney2ns
    • Newburgh Weather
« Reply #2 on: August 17, 2006, 01:54:57 AM »
Thank you very much. I appreciate the calculations!  :D
