cloudy
Author Topic: AJAX Weather Question  (Read 2720 times)
Offline CNYWeather
  • Professional Trophymaker!
  • Rome, New York
    • CNYWeather.com
« on: July 12, 2006, 11:25:55 PM »
I've been looking at the AJAX pages that Pinto (?) has put up available
for download. Is there a download of a template like Tom @ Carterlake.org available?
Thanks in advance,
Tony
Tony
CNYWeather.com
CWOP: CW2352
WeatherUnderground: KNYWESTM1
http://www.CNYWeather.com
I Make Trophies Too!
http://www.speedyawards.com
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: AJAX Weather Question
« Reply #1 on: July 12, 2006, 11:53:12 PM »
The carterlake template should be in the WD download package now. Otherwise click web template on http://www.carterlake.org/
« Reply #2 on: July 13, 2006, 12:08:17 AM »
the new ajax template is not ....though....but there is a thread on how they did they ajax stuff in the cutom templates part of the forum....
i wouldnt mind trying myself
Offline carterlake
  • Tom Chaplin
  • Carter Lake, Iowa USA
    • Carter Lake, Iowa Weather
« Reply #3 on: July 13, 2006, 12:43:56 AM »
Thread is here:
http://www.weather-watch.com/smf/index.php/topic,16311.0.html
Template is... well... I guess we never made one....
Here is an example page:
http://www.joske-online.be/ajaxweather.html
WD; Davis VP2 6153; Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; Live NOAA radio
« Reply #4 on: July 13, 2006, 09:31:24 PM »
i tried a test, but ended up with a permission denied on the GET command...in the java script...
Offline carterlake
  • Tom Chaplin
« Reply #5 on: July 13, 2006, 11:02:46 PM »
Brian, have you got a test page up?
« Reply #6 on: July 13, 2006, 11:06:49 PM »
http://www.weather-display.com/windy/gb/wxlocal.html
it has the custom tags, but the ajax stuff should still work...
let me know what i have done wrong....
i also uploaded the needed .js file too...
thanks Tom!
Offline carterlake
  • Tom Chaplin
« Reply #7 on: July 13, 2006, 11:16:02 PM »
thanks Tom!
I think it's where your client raw files are located...
And don't forget editing the location in the clrextra.js
« Reply #8 on: July 13, 2006, 11:38:16 PM »
ah, ok,,,,that looks like it done it....check out that page now....you can see the temperature over the top of other words.....so that part is working, just a coding issue now..
i will need to have the html be in the same folder as the clientraw file then.....
« Reply #9 on: July 14, 2006, 12:18:11 AM »
http://www.weather-display.com/windy/wxlocal.html
temperature,windspeed,direction, rain,baro...
working...as a test....but has to be where the clientraw file is located....
i could shift that....but will have to change MML...
« Reply #10 on: July 14, 2006, 12:39:33 AM »
cool bananas  :D
working great....by just using a separate page...linked from my main page....
i.e
http://www.weather-display.com/windy/wx2.html
linked from
http://www.weather-display.com/windy/grahhamsbeach.htm
which i have set wd to create and upload as ewll, but upload to the directory above (using .. )
lets see how that all works :)
one problem is, the ajax data is creating a line return??
« Last Edit: July 14, 2006, 12:51:14 AM by windy »
Offline weatheroz
  • Brendan
  • Logan Village, Queensland, Australia
    • Logan Village Weather
« Reply #11 on: July 14, 2006, 03:09:13 AM »
I'm having a bit of a problem with my ajax page in Internet Exploder, works fine in Firefox though.
http://www.loganvillageweather.com/index.php includes the following file http://www.loganvillageweather.com/ajaxweather.php where all the ajax stuff is.
IE displays all but the actual readings, whereas Firefox displays the lot as expect, and this is on 3 different computers.
edit: when the second link is loaded by itself, it works fine, but when it is included in the index.php it does not work.
« Last Edit: July 14, 2006, 03:20:37 AM by weatheroz »
« Reply #12 on: July 14, 2006, 03:17:21 AM »
i can see the reading in IE OK, but they are way off to the right...
Offline weatheroz
  • Brendan
« Reply #13 on: July 14, 2006, 03:19:47 AM »
Sorry, I meant to add that the actual include file works when loaded by itself, but won't work when included in another page.
« Reply #14 on: July 14, 2006, 03:22:50 AM »
<body background="../white" style="margin-top:0;margin-left:0;margin-right:0;margin-bottom:0;">
put that line after the
<body onload="JavaScript: ajaxLoader('clientraw.txt?'+new Date());" >
try that
