I'm a bit surprised to see your ISS up there though. Do you use your chimney? I would think that and the roof would effect your readings a bit.
Yes, it is mounted to the chimney. Was the best I could do to get the anemometer up away from most of the tree line. I wasn't going to put the ISS up there, and I bought a transmitter for the anemometer, but in the end decided to try with everything mounted on the mast. I think the FARS does a good job of not allowing the roof to affect the temps.
I am going to move everything...I am looking at 40ft telescoping masts right now. My ISP wants to move my wireless connection to a different source antenna and I don't have a clear line-of-sight from the house (the webcam can see the tower ok). So I think I am going to bite the bullet and get a real mast to mount everything on. I am still not happy with my wind readings, just to many tall tress blocking the air so I have to do something...
The Canon webcam is not cheap...the only competition that I know of is the Stardot (and it doesn't have p/t/z). The Canon is an amazing camera with great picture quality, an optical (and digital) zoom, p/t/z, and a built-in webserver. The dome supplies power for the webcam and also contains a heater/blower. The dome wasn't cheap either, but being able to run 24VAC instead of 115VAC makes it alot nicer (I used 4-strand wire used for yard water-sprinkler setups). The dome has the electronics to convert the 24VAC to 9VDC the camera needs.
If I had it to do over I wouldn't buy the inverted webcam...I would get the desktop version and then a dome that would allow the webcam to look up. My setup is great for looking down, a security camera type setup. I think a weather-cam should be able to look up towards the sky and clouds.
SWMBO says I have to disable the webcams ability to look at the pool so I will be working on that this afternoon
