Ajax Powered Pages
I think this needs it’s own thread. VERY SPECIAL THANK YOU TO PINTO!
http://www.joske-online.be/
It’s VERY exciting, doing the same thing as WU rapidfire and WD live but on our own webpages.
I’m currently live on:
http://www.carterlake.org
Using PHP, I give visitors the option of disabling live:
http://www.carterlake.org/index.php?liveoff=1
Check out Pinto’s code at: http://www.joske-online.be/ajaxweather.html and view source.
Aha, looking good. Congrats to you both.
Could I suggest displaying an updated time ?
[quote author=nikoshepherd
Outstanding…
New toys to play with :slight_smile:
Good Job on implementing Tom.
Somewhere close by the “Current” label maybe?
Very neat, Tom.
Thanks for sharing…I’m sure I will be messing around with it sometime soon… :wink:
–Tim
Don’t thank me… thank Pinto =D>
Now I just have to work on a few things…
Adding more tags…
Figuring out what to do when the tags don’t load (which is every once and awhile).
good stuff indeed
i know that Julian had a proof of concept working a while ago now too :slight_smile:
(but because there was so much involved with getting ajax set up and it was new,and it would compete wtih WDL, it went no further :slight_smile:
I was doing a bit of a refresher on Ajax a couple of weeks ago and whilst it does have some promise, it’s not all plain sailing…if the information I found was to be believed and I have no reason to suspect that it was intended to be misleading.
Unfortunately I seem to have forgotten to bookmark a page which listed a number of issues, so I can’t recall all of them. I’m fairly sure that one significant area was browser compatibility.
The issues I saw led me to conclude that Ajax wasn’t (yet) a suitable tool to use for what I wanted to do.
I would agree with you except that 97% of my visitors can use Ajax. If only PHP detected javascript enabled, I could easily take care of the other 3%. I’ll have to find a workaround instead (like having the ability to disable Ajax, which I’ve already encorporated).
It wasn’t simply an issue of scripting being disabled. If I remember correctly there are some browsers which have ‘broken’ versions of Javascript which have a range of problems with Ajax sites, others where the Javascript processing is very slow if you have large Javascript files and there also appeared to be a range of other problems, many just minor irritants/cosmetic issues. Ajax is pretty new, so it’s to be expected that it’s got issues. Maybe some of the problems I saw have already been fixed…with others probably introduced as well!
browsers tested: FF, IE and opera
They all work :smiley:
We also have an old copy of IE 5.5 … worked on that as well…
My idea is to use PHP :smiley: to display the code and to display the static info if Javascript is disabled.
The idea will be for seamless displaying with or without javascript.
http://en.wikipedia.org/wiki/AJAX#Cons_and_criticism has some of the issues, but I found a more detailed description of some of the problems elsewhere.
I just want to point out that this script is no new wdl, it is just a small javascript to change some value’s on a page using the clientraw.txt-file like on Tom’s and Julians page
:slight_smile:
Great stuff, Pinto and Tom! Thanks for showing us examples with your pages.
I found that updating pages realtime with clientraw.txt will sometimes yield zeroes for results… probably trying to access the clientraw.txt just when it was being ftp’ed, so I’d recommend putting in a small check to see the field[0] contains ‘12345’, and if it doesn’t, wait a second or two and try the access again. That fixed issues I’d had with Anole’s wxsticker sometimes displaying a data that wasn’t correct.
Ken
one good thing to do with the clientraw file is to set WD’s FTP to rename the file…but that only works if your FTP server allows that
yes, great work on making this available :slight_smile:
I have done that now and it does work great
thanks :smiley:
see brian’s post just above, that did it for me :slight_smile:
the way its done looks similar to Greg Hughes SVG system …?
