cloudy
Author Topic: FWI Startup Values  (Read 57986 times)
Offline NorCal Dan
  • -= Dan =-
  • Marysville, California
    • Skype @ KJ6RGX
    • Traveling RV Weather
Re: FWI Startup Values
« Reply #45 on: January 18, 2007, 06:40:38 PM »
Do you still need help setting up the FWI?
warwickpaweather
  • Guest
« Reply #46 on: May 11, 2007, 08:10:26 PM »
Yeah I need help....I live in the Eastern Prt of Pennsylvania just north of Philly (about 30 miles)....There's noplace that I can find the startup values, nor anything else WD needs to calculate, update and upload the info for me.
Offline NorCal Dan
  • -= Dan =-
    • Skype @ KJ6RGX
« Reply #47 on: May 12, 2007, 12:59:56 AM »
The site I use to find my numbers is http://www.wfas.us/content/view/17/32/.  While it doesn't list the numbers your looking for, you can make some rough estimates based on their data.  For instance, http://www.fs.fed.us/land/wfas/kbdi.gif is the Keetch-Byram index.  Some of the other graphs deal with moisture and you can use those for the DMC and DC.
While it would be nice to have the exact figures the site should provide you with enough data to get your readings started.  Keep in mind that some of the readings take over 50 days to start tracking.   I don't recommend you make changes after you set it up unless absolutely necessary.  If you keep making changes the data will take a long time to track with your weather.  Also, it doesn't take much rain to drop the FWI to near zero, so if you get rain and it drops just leave it and it should track back.
I think Brian is working on the FWI module.
Offline NorCal Dan
  • -= Dan =-
    • Skype @ KJ6RGX
« Reply #48 on: June 14, 2007, 05:47:08 PM »
Were you able to set your initial values?  After researching your area using the site I posted it doesn't appear you have much of a fire danger in your area.  The moisture content is high and the drought code is low.  I see you have your numbers posted on your site, just wondering if those are current?  WD should re-calculate them at 1300 hours daily.
Here's a good site that explains the values Brian uses in the FWI setup.
http://www.nrfa.org.nz/fire_weather/fwi_help/values_triggers.htm
« Last Edit: June 14, 2007, 05:52:21 PM by NorCal Dan »
Offline n9mfk9
  • Springfield IL, USA
« Reply #49 on: August 30, 2007, 04:51:00 PM »
Hi everyone,
I am in IL. if I set the last to boxes
rain fall an Byram-Keetch drought index.
will that get me started or do i need to set all boxes
thanks
Offline Phoniclynx
  • Adelaide, Australia
    • Tucker's Weather Station
« Reply #50 on: December 29, 2007, 12:57:11 AM »
anyone managed to find anything for Australia yet?
Tucker
Adelaide Australia.
Dell Lattitude Laptop, 1GB, 500GB HDD
AAG 1-Wire Network, Baro, Humidity Sensor, V3 Weather Station, Rain Gauge, Solar Sensor, HUB
Offline tpfrs
  • Tom Price Western Australia
    • Tom Price Fire & Rescue Service
« Reply #51 on: January 03, 2008, 02:48:22 PM »
Not yet. Though I keep pestering BoM!!!
Offline weatheroz
  • Brendan
  • Logan Village, Queensland, Australia
    • Logan Village Weather
« Reply #52 on: January 29, 2008, 01:58:46 AM »
Oh bugger, was hoping we'd find something sooner rather than later.
Offline thill
  • Canberra, ACT, Australia
    • Evatt ACT Weather
« Reply #53 on: March 06, 2008, 11:14:21 AM »
Try your local CFS brigade, or the head office.  Over here in ACT/NSW we can access a range of FWI data from NSW and ACT RFS websites,supplied by the BOM.
Cheers
Offline Gandalf
« Reply #54 on: May 14, 2008, 11:41:01 PM »
Any idea how I get this to work for Tasmania Australia? Anywhere I can get the info from, I am getting some readings at the moment, but I don't know if they are accurate. I also have to update it manually as it doesn't do it automatically
Cheers
« Reply #55 on: May 14, 2008, 11:42:20 PM »
it should update auto, does for me and others
as along as you have the switch on under view, FWI
but maybe you meand up to the web site? (its not clear)
(if so then make sure you have ticked, upload to web site)
Offline Gandalf
« Reply #56 on: May 15, 2008, 12:01:56 AM »
Hi Brian, it's all vey weird. I seem to have some data in the FWI (don't know where it's coming from, having read just that folks can't get info for Australia)Where is the info coming from, is it accurate, and how the heck did I manage to get it set up?   :wink: http://people.aapt.net.au/~tell18/fwi.htm
« Reply #57 on: May 15, 2008, 12:02:42 AM »
WD does its own FWI calculations from your data
Offline Gandalf
« Reply #58 on: May 21, 2008, 01:29:23 AM »
Cheers Brian, so it does. All the data is up to date, don'tknow what was happening before, but it's working just fine now.  :)
abaldish
  • Guest
« Reply #59 on: May 28, 2008, 03:41:19 PM »
Hello All,
Yea i am back at trying to figure this FWI settings again.
Called the NWS and they didn't know anything about the data i needed to input in there. Now the system is showing this:
Last Updated: 05/27/08 at noon
Current Weather conditions
TEMP(°F)   RH(%)   WIND(mph)   DIRECTION   24 HOUR RAIN (mm)
78.3             62           5.2                 345              8.1
Yesterdays values
FFMC     DMC     DC     ISI      BUI      FWI
79.2         1        18       1.2          1         0.3
Todays values
43.5         0         12      0.1          1         0.0
Does anyone know where i can get the settings for the FFMC, DMC, DC, ISI, BUI for my area in simple terms?
