cloudy
Author Topic: La Crosse 3600 and WD  (Read 6999 times)
« on: January 29, 2006, 08:24:43 PM »
i think one thing to note that has come to light with the 3600
is that you need to set the com port to a number that the 3600 is not set to
so that wd then does not conflict with heavy weather (i.e you select the heavy weather update file history.dat (and leave heavy weather running) or the fetch3600 program (if you have set to use that (and then dont run the heavy weather program)) for the com port
and then if using the fetch3600 method, make sure in the open3600.conf file, the correct com port number is set there
