can you try again selecting german for the VP forecast in the summary image and icon setup?
why are you using the com port release?
=> when i try reselect german language: no effect but somtimes effect after many tries. and after one minute english language again.
when i chose any other language then this choice stabil, but other mayor errors still occur.
=> i use the com port release because other software (weatherlink) any half hour reads the data-logger. Preferable i use wd for the wd-live feature. the wd- live feature is unreachanable for any other software!
Meanwhile i have experienced with the forecast / summary setup, Maybe it is usefull for you:
Doing effect1. ticked: show no icons at all: laguage switched to german automaticaly, all errors where lost!
2. unticked: show no icons at all: surprisely no error, also after restard wd: since about halb an hour is running so!
Because of Nr. 2: I have a look of this and when the error comes back then i make again Nr. 1 and Nr.2
For me is this a good workaround meantime you have the solve.
Now i feel much better!
I found also a point of interest between the time of "normal" function:
a few days ago: the icon in the main screen shows night snow. the icon in the
summary image was "moderate rain" and the text in the summary image was "moderate snow".
I was surprised because i had expected the summary image icon is the same as in the main screen.
