Author Topic: Access Violation  (Read 3900 times)
Offline graphix
  • Laird of Glencairn
  • Swisttal-Odendorf (Germany)
    • http://www.odendorfwetter.de
Access Violation
« on: December 27, 2005, 07:10:53 PM »
hi all ...
just made a brand new "naked" installation of wd 10.31f, made the ftp-settings and a few things needed. clientraw real time works but ftp upload doesn't. no webcam, no metars, nothing special set. and i'm getting this in the program error log:
Code: [Select]
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:53:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:54:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:55:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:56:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:57:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:58:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 20:59:01 27.12.05
ERROR: Access violation at address 00404148 in module 'WeatherD.exe'. Write of address 00986854 at time/date 21:00:01 27.12.05
seems that this error occures every minute. manual upload of the files works, but ftpuload does not work ...
please help me! my weather page looks horrible without data ... using davis vantage pro 2, windows 2000 sp4.
Offline meteofrog
  • AUSTRIA (48°29'26"N 16°39'30"E)
    • Meteonex
Re: Access Violation
« Reply #1 on: December 27, 2005, 07:49:34 PM »
same here.
10.31f worked for 3 days without a porblem.
Suddenly today WD stopped uploading data. Manual upload is working.
In the prog error log are the same errors reported as mentioned in that thread before.
meteofrog
System:
Win XP / Intel Celeron 2.0 / ADSL
ZoneAlarm, AntiVir, latest Vers WD
VANTAGE pro 1 wireless, soil temp, leaf wetness, solar
mah291069
  • Guest
« Reply #2 on: December 27, 2005, 09:01:57 PM »
Offline NorCal Dan
  • -= Dan =-
  • Marysville, California
    • Skype @ KJ6RGX
    • Traveling RV Weather
« Reply #3 on: December 27, 2005, 09:23:58 PM »
Might not help, but have you tried the debug version to see if it captures any errors?  I get those errors also but it doesn't seem to effect WD as it continues to upload.  Running 10.31c here...
Offline graphix
« Reply #4 on: December 27, 2005, 09:49:13 PM »
yes, i just installed the debug version and send the errors via smtp. hope it helps and brian has any solution. i tried several different versions (exe-files) of wd 10.30k, 10.30o and others by changing only the exe-file. same errors every time. maybe the problem is not wd itself. maybe its ftpupd.exe?? i don't know ...
Offline JaxWeather
  • Bob
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #5 on: December 28, 2005, 01:08:23 AM »
I have ftpupd.exe from 10.30n here:
http://actionstep.com/WD-Past/
If you want to try just replacing that and see what happens...
Offline graphix
« Reply #6 on: December 28, 2005, 07:38:12 AM »
here is what the debug version says:
Code: [Select]
EurekaLog 5.0.1
Application:
  1.1 Start Date      : Wed, 28 Dec 2005 09:36:19 +0100
  1.2 Name/Description: Weather Display
  1.3 Version Number  : 10.30.0.0
  1.4 Parameters      :
  1.5 Compilation Date: Sat, 17 Dec 2005 00:57:21 +0100
Exception:
  2.1 Date   : Wed, 28 Dec 2005 09:37:01 +0100
  2.2 Address: 00404250
  2.3 Module : WeatherD.exe
  2.4 Type   : Unknown exception type.
  2.5 Message: Unknown error message.
Active Controls:
  3.1 Form Class   : TMainForm
  3.2 Form Text    : Weather Display - Ver 10.31c - Registered  -DAVIS Vantage Pro   N,0.0 kmh,-1.4 °C,0.0 mm
  3.3 Control Class: TAbGearDial
  3.4 Control Text :
Computer:
  4.1 Name          : PEGASUS
  4.2 User          : momo
  4.3 Total Memory  : 1023 Mb
  4.4 Free Memory   : 571 Mb
  4.5 Total Disk    : 37,25 Gb
  4.6 Free Disk     : 14,11 Gb
  4.7 System Up Time: 00:07:29:47
  4.8 Processor     : Intel(R) Pentium(R) 4 CPU 3.00GHz
  4.9 Display Mode  : 1280 x 1024 x 32
Operating System:
  5.1 Type    : Microsoft Windows 2000
  5.2 Build # : 2195
  5.3 Update  : Service Pack 4
  5.4 Language: Deutsch (Deutschland)
Network:
  6.1 IP Address: 192.168.2.9
  6.2 Submask   : 255.255.255.0
  6.3 Gateway   : 192.168.2.1
  6.4 DNS 1     : 192.168.2.1
  6.5 DNS 2     :
  6.6 DHCP      : ON
Call Stack Information:
|Address |Module      |Unit        |Class            |Procedure/Method       |Line |
| Running Thread: ID=1756; Priority=0; Class=; [Main]                              |
|0093DA4D|WeatherD.exe|timer1.pas  |TFormtimer1      |Timer1Timer            |3321 |
|00936FC8|WeatherD.exe|timer1.pas  |TFormtimer1      |Timer1Timer            |695  |
|00B919D6|WeatherD.exe|units.pas   |TFormunits       |Timer4Timer            |26499|
|77E2C9D8|user32.dll  |            |                 |IsWindowVisible        |     |
|77E17ED1|user32.dll  |            |                 |DispatchMessageA       |     |
|77E17ECB|user32.dll  |            |                 |DispatchMessageA       |     |
|00E38DB2|WeatherD.exe|WeatherD.DPR|                 |                       |407  |
| Running Thread: ID=2112; Priority=0; Class=                                      |
|77E9A28D|kernel32.dll|            |                 |SleepEx                |     |
|77E9A25D|kernel32.dll|            |                 |SleepEx                |     |
|004936C0|WeatherD.exe|_AbFlash.pas|TTimerThread     |Execute                |86   |
|00493258|WeatherD.exe|AbThread.pas|                 |ThreadProc             |173  |
| Calling Thread: ID=1756; Priority=0; Class=; [Main]                              |
|004933F7|WeatherD.exe|AbThread.pas|TAbThread        |Resume                 |264  |
|004933F0|WeatherD.exe|AbThread.pas|TAbThread        |Resume                 |263  |
|004937F6|WeatherD.exe|_AbFlash.pas|TAbFlash         |UpdateTimer            |121  |
|004937BC|WeatherD.exe|_AbFlash.pas|TAbFlash         |UpdateTimer            |116  |
|0049384B|WeatherD.exe|_AbFlash.pas|TAbFlash         |SetOnTimer             |154  |
|00493828|WeatherD.exe|_AbFlash.pas|TAbFlash         |SetOnTimer             |151  |
|00493A85|WeatherD.exe|AbFlashT.pas|TAbFlashTimer    |create                 |119  |
|00493A38|WeatherD.exe|AbFlashT.pas|TAbFlashTimer    |create                 |114  |
|004939E2|WeatherD.exe|AbFlashT.pas|                 |CreateTimer            |96   |
|004939D0|WeatherD.exe|AbFlashT.pas|                 |CreateTimer            |95   |
|00493F86|WeatherD.exe|AbFlashT.pas|                 |AddControl             |329  |
|00493E88|WeatherD.exe|AbFlashT.pas|                 |AddControl             |298  |
|005116F2|WeatherD.exe|AbRMeter.pas|TAbRMeter        |PointerFlash           |388  |
|005116B4|WeatherD.exe|AbRMeter.pas|TAbRMeter        |PointerFlash           |384  |
|00511718|WeatherD.exe|AbRMeter.pas|TAbRMeter        |LimitChange            |405  |
|0049C82C|WeatherD.exe|_GClass.pas |TAbAnalogGControl|LimitCheck             |4035 |
|0049C7DC|WeatherD.exe|_GClass.pas |TAbAnalogGControl|LimitCheck             |4024 |
|0049CDF4|WeatherD.exe|_GClass.pas |TAbAnalogGControl|ValueChange            |4249 |
|0049CBD8|WeatherD.exe|_GClass.pas |TAbAnalogGControl|ValueChange            |4182 |
|00512618|WeatherD.exe|AbRMeter.pas|TAbRMeter        |ValueChange            |760  |
|0049D1AF|WeatherD.exe|_GClass.pas |TAbAnalogGControl|SetDigit               |4354 |
|77E2BA5E|user32.dll  |            |                 |IsWindow               |     |
|77887FC0|ntdll.dll   |            |                 |RtlLeaveCriticalSection|     |
|00E3893E|WeatherD.exe|WeatherD.DPR|                 |                       |282  |
Modules Information:
|Handle  |Name              |Description                                     |Version      |Size    |Modified           |Path                                   |
|00230000|PAKBUSDLL.DLL     |                                                |             |114688  |2003-08-07 08:31:06|J:\wd                                  |
|00260000|ljackuw.dll       |                                                |             |73728   |2004-10-28 14:02:00|J:\wd                                  |
|00280000|HID.DLL           |Hid User Library                                |4.10.0.2222  |36864   |1999-04-23 22:22:00|J:\wd                                  |
|00370000|MPRAPI.DLL        |Windows NT MP Router Administration DLL         |5.0.2181.1   |81168   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|00400000|WeatherD.exe      |Weather Display                                 |10.30.0.0    |19709440|2005-12-17 12:57:26|J:\wd                                  |
|04DD0000|wnaspi32.dll      |                                                |             |6656    |2005-07-01 01:08:54|C:\WINNT\system32                      |
|04DE0000|D3d8.dll          |Microsoft Direct3D                              |5.3.1.904    |1179648 |2004-07-09 04:27:28|C:\WINNT\system32                      |
|04F10000|d3d8thk.dll       |Microsoft Direct3D OS Thunk Layer               |5.3.0.900    |7168    |2002-12-12 00:14:32|C:\WINNT\system32                      |
|04F30000|Msdmo.dll         |                                                |6.5.1.900    |13312   |2002-12-12 00:14:32|C:\WINNT\system32                      |
|04F40000|BtBalloon.dll     |Balloon Tooltip Routine DLL                     |3.0.1.912    |49152   |2004-10-01 22:56:24|C:\Programme\Sitecom\Bluetooth Software|
|055F0000|shellextension.dll|Microsoft AntiSpyware Shell Extension           |1.0.701.10   |101080  |2005-11-15 12:12:06|C:\Programme\Microsoft AntiSpyware     |
|05650000|MSI.DLL           |Windows Installer                               |3.1.4000.2435|2890240 |2005-05-04 13:45:32|C:\WINNT\system32                      |
|10000000|IBFS32.DLL        |FF IBFS32 V3.21Beta 11/20/02 (IBFS32.DLL)       |3.2.1.3      |131072  |2002-11-20 15:44:38|J:\wd                                  |
|51000000|DDraw.dll         |Microsoft DirectDraw                            |5.3.1.904    |265728  |2004-07-09 04:27:28|C:\WINNT\system32                      |
|51080000|DSound.dll        |DirectSound                                     |5.3.1.904    |363520  |2004-07-09 04:27:28|C:\WINNT\system32                      |
|5EF80000|Ksuser.dll        |User CSA Library                                |5.3.0.900    |4096    |2002-12-12 00:14:32|C:\WINNT\system32                      |
|60F00000|Ksproxy.ax        |WDM Streaming ActiveMovie Proxy                 |5.3.0.900    |117248  |2002-12-12 00:14:32|C:\WINNT\system32                      |
|68F30000|PSAPI.DLL         |Process Status Helper                           |5.0.2134.1   |28944   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|69470000|olepro32.dll      |                                                |5.0.4522.0   |164112  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|6A770000|MSVFW32.dll       |DLL für Microsoft Video für Windows             |5.0.2195.6612|117520  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|71710000|COMCTL32.dll      |Common Controls Library                         |5.81.4916.400|529680  |2002-08-29 09:32:28|C:\WINNT\system32                      |
|72810000|DCIMAN32.dll      |DCI Manager                                     |5.0.2180.1   |8464    |2003-06-20 13:00:00|C:\WINNT\system32                      |
|747E0000|avifil32.dll      |Microsoft AVI-Dateiunterstützungs-Bibliothek    |5.0.2195.6612|78608   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|74800000|AVICAP32.dll      |AVI Capture Window Class                        |5.0.2134.1   |67344   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|74F90000|WS2HELP.DLL       |Windows Socket 2.0 Helper für Windows NT        |5.0.2134.1   |18192   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|74FA0000|WS2_32.DLL        |Windows Socket 2.0 32-Bit DLL                   |5.0.2195.6601|69904   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|74FC0000|wsock32.dll       |Windows-Socket 32-Bit-DLL                       |5.0.2195.6603|23824   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|750C0000|SAMLIB.DLL        |SAM Library DLL                                 |5.0.2195.6944|51984   |2005-06-02 23:44:58|C:\WINNT\system32                      |
|75130000|NETRAP.dll        |Net Remote Admin Protocol DLL                   |5.0.2134.1   |11536   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|75940000|LZ32.DLL          |LZ Expand/Compress API DLL                      |5.0.2195.6611|10000   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|75DF0000|IMM32.DLL         |Windows 2000 IMM32 API Client DLL               |5.0.2195.6655|96528   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|76B00000|comdlg32.dll      |Common Dialog-DLL                               |5.0.3700.6693|245520  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77090000|CSCDLL.DLL        |Offlinenetzwerk-Agent                           |5.0.2195.6713|102160  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|772A0000|SHLWAPI.dll       |Shell Light-weight Utility Library              |6.0.2800.1740|409600  |2005-08-31 17:51:46|C:\WINNT\system32                      |
|77310000|iphlpapi.dll      |IP-Hilfs-API                                    |5.0.2195.6602|70416   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77330000|DHCPCSVC.DLL      |DHCP Clientdienst                               |5.0.2195.6685|93456   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77350000|ADSLDPC.DLL       |DLL für ADs LDAP Provider C                     |5.0.2195.6993|134928  |2005-06-02 23:44:42|C:\WINNT\system32                      |
|77380000|ACTIVEDS.DLL      |ADs Router-Ebene-DLL                            |5.0.2195.6601|182544  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|773E0000|MSACM32.dll       |Microsoft ACM-Audiofilter                       |5.0.2134.1   |66832   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77490000|rasman.dll        |Remote Access Connection Manager                |5.0.2195.6824|58128   |2005-06-02 23:44:40|C:\WINNT\system32                      |
|774B0000|RASAPI32.DLL      |Remote Access API                               |5.0.2195.6920|200464  |2005-06-02 23:44:40|C:\WINNT\system32                      |
|774F0000|ICMP.DLL          |ICMP DLL                                        |5.0.2134.1   |7440    |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77500000|TAPI32.dll        |Microsoft® Windows(TM) Telefonie-API-Client-DLL |5.0.2195.6664|126736  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77530000|wdmaud.drv        |WDM Audio driver mapper                         |5.0.2195.6673|21264   |2003-06-19 11:05:04|C:\WINNT\system32                      |
|77540000|winmm.dll         |MCI API-DLL                                     |5.0.2161.1   |191248  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|777F0000|winspool.drv      |Windows-Spoolertreiber                          |5.0.2195.6659|114448  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77810000|version.dll       |Version Checking and File Installation Libraries|5.0.2195.6623|16144   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77820000|RTUTILS.DLL       |Routing Utilities                               |5.0.2168.1   |44816   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77840000|cscui.dll         |Clientseitige Cachebenutzeroberfläche           |5.0.2195.6705|247568  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77880000|ntdll.dll         |DLL für NT-Layer                                |5.0.2195.7006|505616  |2005-06-02 23:44:36|C:\WINNT\system32                      |
|77940000|WLDAP32.DLL       |Win32 LDAP-API-DLL                              |5.0.2195.7017|146704  |2005-06-02 23:44:40|C:\WINNT\system32                      |
|77970000|DNSAPI.dll        |DNS Client API DLL                              |5.0.2195.7003|136976  |2005-06-02 23:44:40|C:\WINNT\system32                      |
|779A0000|oleaut32.dll      |                                                |2.40.4522.0  |626960  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77BE0000|NTDSAPI.dll       |NT5DS                                           |5.0.2195.6666|57616   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|77D20000|RPCRT4.dll        |Remote Procedure Call Runtime                   |5.0.2195.7020|477968  |2005-06-02 23:44:38|C:\WINNT\system32                      |
|77E00000|user32.dll        |Client-DLL für Windows 2000 USER-API            |5.0.2195.7032|420112  |2005-06-02 23:44:38|C:\WINNT\system32                      |
|77E70000|kernel32.dll      |Client-DLL für Windows NT-Basis-API             |5.0.2195.7006|768272  |2005-06-02 23:44:38|C:\WINNT\system32                      |
|77F40000|GDI32.dll         |GDI Client DLL                                  |5.0.2195.7069|233744  |2005-10-07 07:19:30|C:\WINNT\system32                      |
|78000000|msvcrt.dll        |Microsoft (R) C Runtime Library                 |6.1.9844.0   |286773  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|782F0000|mpr.dll           |Router-DLL für Mehrfachanbieter                 |5.0.2195.6824|57104   |2005-06-02 23:44:50|C:\WINNT\system32                      |
|78310000|SETUPAPI.dll      |Windows 2000 Setup-API                          |5.0.2195.6622|582416  |2003-06-20 13:00:00|C:\WINNT\system32                      |
|784A0000|CLBCATQ.DLL       |                                                |2000.2.3529.0|551184  |2005-09-05 09:18:20|C:\WINNT\system32                      |
|791A0000|USERENV.DLL       |Userenv                                         |5.0.2195.7002|404752  |2005-06-02 23:44:38|C:\WINNT\system32                      |
|79350000|advapi32.dll      |Erweitertes Windows 32 Base-API                 |5.0.2195.7038|401680  |2005-06-02 23:44:38|C:\WINNT\system32                      |
|79430000|SECUR32.DLL       |Security Support Provider Interface             |5.0.2195.6695|48912   |2003-06-20 13:00:00|C:\WINNT\system32                      |
|7CE20000|NETAPI32.DLL      |Net Win32 API DLL                               |5.0.2195.7038|326928  |2005-06-02 23:44:54|C:\WINNT\system32                      |
|7CE80000|ole32.dll         |Microsoft OLE für Windows                       |5.0.2195.7059|957712  |2005-09-05 09:18:18|C:\WINNT\system32                      |
|7CF90000|shell32.dll       |Windows Shell Common Dll                        |5.0.3900.7071|2385168 |2005-09-23 12:03:10|C:\WINNT\system32                      |
Registers:
i'm now installing the ftpupd.exe from the 10.30n for testing ... let' see what happens.
update: that wasn't the right clue. even with ftpupd.exe from 10.30n the same problems. must be something else ...
« Last Edit: December 28, 2005, 07:51:28 AM by graphix »
Offline graphix
« Reply #7 on: December 29, 2005, 04:02:54 PM »
still hanging with my problems ... has no one got a clue??
Offline meteofrog
    • Meteonex
« Reply #8 on: December 29, 2005, 05:43:57 PM »
So I am.
I think we have to wait til Brian is back again.
I am running at the moment an older version.
meteofrog
System:
Offline cirrus
  • RockCreekResWx
  • WX-200 Weather Station
  • Wamic, OR USA
    • Rock Creek Reservoir Weather
« Reply #9 on: December 30, 2005, 01:15:10 AM »
Graphix,
I'm having problems with the ftpupd.exe version (7.94) that is with WD 10.31f. I'm now using a very reliable older version of ftpupd.exe...version 7.87. The ftpupd.exe version you tried that's with 10.30n....is the same ftpupd.exe version (7.94) that's with 10.31f. So you need to try an older version. I've placed a copy of ftpupd.exe version 7.87 on my web server for you to download and try , if you like.
UPDATE:Sorry....the ftpupd.exe version that is with 10.30n is version 7.92. My bad! :oops: But just to be sure, you could still try ftpupd.exe 7.87
Here's the download link:
http://rockcreekweather.com/wdpast/ftpupd_7.87.zip
Windy, here's a screen shot of my drwatson error log showing the error. Maybe it has some usefull info?
« Last Edit: December 30, 2005, 04:30:38 AM by cirrus »
Offline graphix
« Reply #10 on: December 30, 2005, 03:18:09 PM »
@ meteofrog
i'm currently running wd 10.28z with ftpupd 7.81. it's fine for me and everything works great at the moment. this can't be a solution for the future but for now its ok. i guess you're right and we'll have to wait til brian is back before we can start another try.
@ cirrus
thx for your help. i didn't try the 7.87 yet because i'm glad wd works for the moment. never change a running system ...  :D
« Reply #11 on: December 30, 2005, 03:45:32 PM »
that particular error seems to be occuring with the VP forecast icon setting a snow icon
the code looks OK, thats the only clue i have
Offline Jeep
  • Richard
  • Whittier, Ca USA
    • Whittier Weather
« Reply #12 on: December 30, 2005, 04:23:19 PM »
I've been having a problem too. My system has been solid for over a year and I started getting crashes. I did a complete wipe and re-install of windows, and it was still occuring. Sometimes wd would just drop out, sometimes windows itself would crash. Never ran for more than about a half hour. I kept checking things until finally I turned of the main internet switch and WD (& windows) have been up for 3 days now.
The only thing I'm getting in the error log is at the 12am reset, it's saying "invalid data type for 'bias'" and "invalid data type for 'active timebias'"
On the chance it's a hardware problem I have a new motherboard, serial card, & video card coming, should be here any day now. After I put together a new computer for WD, I'm hoping the crashes will go away because I really think it's a hardware problem that WD is somehow aggravating. But I DID find it interisting that the system became stable when I turned the main internet switch off.
« Last Edit: December 30, 2005, 04:40:00 PM by Jeep »
Jeep
« Reply #13 on: December 30, 2005, 08:02:39 PM »
that particular error occurs with win 98 and the new auto detect the time zone
but i now have it where it should not do that if windows 98 is in use...
which windows version are you using jeep, and which version of WD?
Offline Jeep
  • Richard
  • Whittier, Ca USA
    • Whittier Weather
« Reply #14 on: December 31, 2005, 06:55:28 AM »
I was using 10.31f where I was seeing that. I'm now using 10.31c debug and still getting it. But, I turned the main internet switch back on and it's been running for 12+ hours now.
I was running on Win Xp, but with all the crashes I thought maybe a less hardware intensive version of windows would work better so when I re-installed I put on win98se.
It's amazing how FAST win98 is running on a Athlon XP 2400+ processor.  8O
Jeep
