1 wire snow detector
Good evening,
You can give me more information and the configuration about the following product:
Added ability uses(wears out) has 1 wire snow detector (based one the leaf wetness now soil moisture 1 wire chip)
Thank you
Serge
there is work being done on producing a commercialy available 1 wire snow depth sensor, by Nafis
and I am adding support for it
(its based on the same routine as for the 1 wire soil moisture and leafg wetness sensors)
its a work in progress, and i will need to add routines to average the readings and put in temperature compensation
but for now you should get a voltage and temperature reading from the 1 wire sensor
Thank you,
Which are the regulations at the level of WD
Serge
hi
not sure what you mean?
can you explain more?
thanks
what i have added so far is in a new 10.30k version
URL by Nafis
Merci
http://home.nycap.rr.com/nafis/weather/
http://www.howmuchsnow.com/snow/
Looks intersting Brian. I hope the have the ultrasonic one based on Stephan’s up and running in a week or 2. That sensor is already temperature compensated so that should make things a little easier also. Thanks for helping out with this project.
:smiley:
Think snow !!
MikeyM
hi
your one is based on a 0 to 5v ADC
and so i will do a setup just for that type of sensor…and provide an average…and then some calibration…
have you been in contact with nafis about that different design?
Yes, I have been in contact with nafis and have all the parts to build the IR version. I’ve had the parts for a while just never got the time to get the project done and then the ultrasonic one looked easier. I’ll be retiring in 10 1/2 months and hope to have a lot more time to tinker with the weather station then. Ha Ha Thanks again.
:smiley:
MikeyM
[quote author=mikeym link=topic=12339.msg94419#msg94419 date=1132100945]
Brian,
You should also take a look at the new CWOP Snow reporting form (http://www.madis-fsl.org/snow_data_login.html).
It’s meant for manual snow data input, but we should be able write code to emulate the form entry. They have a place for snow depth. They only expect 1" accuracy for the snow depth. They also only expect the data once a day.
It’s a shame they didn’t add the input to the existing CWOP data stream…
I’d rather see data sent every 5 minutes so you can tell what’s going on outside… but it’s a start.
                             Chris
yeah, not exactly very real time only once a day update
i do have a web post update componnent, but not really all that sure who to go about it
maybe some sort of script reading from a file on your website with the data in it?
Brian,
I working a snow detector that is based upon nafis’ design i.e. IR based not ultrasonic. How big of a hassel will it be to intergrate into WD?
WD does find it and records data that is on the attached pic.
I turned it on today and that’s as far as I’ve gotten.
Ed
looking good
you be should be able to have that plotted…check back in the thread for where/how?
Hello,
You Can give us the continuation of your search
Thank you.
Serge
Hi Edhall!
What kind of sensor you have tested with?
I’m interested of a snow-sensor too…
Henkka
I’m working with a Sharp GD2D12. It has a range of 10cm to 80 cm. I’m hoping to run some calibration tests this week. Trouble is I’m having a hard time getting my test program to compile – issues with some header files.
Ed
