Author Topic: 1 wire snow detector  (Read 6125 times)
Offline eongibier
  • Vaisala 520 - Détecteur de hauteur de neige
  • Château des Prés (France Haut-Jura)
« on: November 14, 2005, 07:12:47 PM »
Good evening,
You can give me more information and the configuration about the following product:
Added ability uses(wears out) has 1 wire snow detector (based one the leaf wetness now soil moisture 1 wire chip)
Thank you
Serge
  • Davis VP2
  • New Zealand
    • Weather Display
Re: 1 wire snow detector
« Reply #1 on: November 14, 2005, 07:16:41 PM »
there is work being done on producing a commercialy available 1 wire snow depth sensor, by Nafis
and I am adding support for it
(its based on the same routine as for the 1 wire soil moisture and leafg wetness sensors)
its a work in progress, and i will need to add routines to average the readings and put in temperature compensation
but for now you should get a voltage and temperature reading from the 1 wire sensor
Offline eongibier
« Reply #2 on: November 14, 2005, 07:29:21 PM »
Thank you,
Which are the regulations at the level of WD
Serge
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: November 14, 2005, 07:35:08 PM »
not sure what you mean?
can you explain more?
thanks
what i have added so far is in a new 10.30k version
Offline eongibier
« Reply #4 on: November 14, 2005, 07:48:12 PM »
URL by Nafis
Merci
Offline mikeym
  • Thornhurst, Pa USA
    • MikeyMs Thornhurst,PA Weather
« Reply #6 on: November 15, 2005, 01:13:57 AM »
Looks intersting Brian. I hope the have the ultrasonic one based on Stephan's up and running in a week or 2. That sensor is already temperature compensated so that should make things a little easier also. Thanks for helping out with this project.
Cheers
 :D
Think snow !!
MikeyM
http://mikeymsweather.com/
Another VERY Happy WD user
Shuttle XS36v4 8 GB RAM
Davis Vantage Pro 2 wireless w/ Davis solar sensor
Laser Snow Depth Sensor LR4/Fluke 414D working in WD thanks to Brian
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #7 on: November 15, 2005, 01:18:33 AM »
your one is based on a 0 to 5v ADC
and so i will do a setup just for that type of sensor...and provide an average...and then some calibration...
have you been in contact with nafis about that different design?
Offline mikeym
« Reply #8 on: November 16, 2005, 12:29:05 AM »
Yes, I have been in contact with nafis and have all the parts to build the IR version. I've had the parts for a while just never got the time to get the project done and then the ultrasonic one looked easier. I'll be retiring in 10 1/2 months and hope to have a lot more time to tinker with the weather station then. Ha Ha  Thanks again.
Cheers
 :D
MikeyM
Offline nafis
    • Vischer Ferry NY Weather
« Reply #9 on: November 17, 2005, 02:50:58 AM »
Cheers
 :D
MikeyM
Mike,
I also prototyped an ultrasonic one based on the Parallax PING sensor (http://www.howmuchsnow.com/ping/).
The PING sensor is not temperature compensated like the SensComp one used in Steinar's prototype (http://voksenlia.net/met/snow.php), so I had to measure the temperature too.
So far the US sensor seems to drift around +/- 0.3"
                      Chris
Offline nafis
« Reply #10 on: November 17, 2005, 03:11:24 AM »
Brian,
You should also take a look at the new CWOP Snow reporting form (http://www.madis-fsl.org/snow_data_login.html).
It's meant for manual snow data input, but we should be able write code to emulate the form entry. They have a place for snow depth. They only expect 1" accuracy for the snow depth. They also only expect the data once a day.
It's a shame they didn't add the input to the existing CWOP data stream...
I'd rather see data sent every 5 minutes so you can tell what's going on outside... but it's a start.
                                 Chris
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #11 on: November 17, 2005, 03:17:26 AM »
yeah, not exactly very real time only once a day update
i do have a web post update componnent, but not really all that sure who to go about it
maybe some sort of script reading from a file on your website with the data in it?
Offline edhall
  • Fulton, MO
    • Ed's Weather
« Reply #12 on: June 30, 2007, 03:27:13 PM »
Brian,
I working a snow detector that is based upon nafis' design i.e. IR based not ultrasonic.  How big of a hassel will it be to intergrate into WD?
WD does find it and records data that is on the attached pic.
I turned it on today and that's as far as I've gotten.
Ed
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #13 on: June 30, 2007, 08:48:25 PM »
looking good
you be should be able to have that plotted.....check back in the thread for where/how?
Offline eongibier
« Reply #14 on: July 02, 2007, 03:53:38 AM »
Hello,
You Can give us the continuation of your search
Thank you.
Serge
