cloudy
Author Topic: Weatherunderground upload error  (Read 2234 times)
Offline krunch2
  • Tom
  • Billings Oklahoma, USA
    • Billings Weather
« on: October 28, 2005, 02:59:45 PM »
I am using 1029z rev  with a clean install. I have everthing working properly except mu upload to weatherunderground. In the ftp log I have this error 151: 400 Bad Request
any suggestions?   Anything Weather, APRS and my weg page are ok
Thanks  Tom
Offline JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
Re: Weatherunderground upload error
« Reply #1 on: October 28, 2005, 03:11:37 PM »
I don't see any  errors in my FTP log from Wunderground however my data last updated at 10:45 AM ET and I started 10.29z rev at 10:56 AM ET   Not sure what is up here....
Edit: Cleared my FTP log.  Waited for the XX:30 Wunderground upload..  Viewing the log I see the following:
--------begin paste--------------------
FTPUPD.EXE started at 12:30:47 PM 10/28/05
****agenda items to do...****
dowunderground
do aprs data send
doupload
doupload
doupload
doupload
dowapupload
*******Files to upload********
-------------------------end paste--------------------
It lists all of the local files and then remote files and then FTPUPD.EXE starts again at XX:31
I see no further indication it was done or experienced any errors...
« Last Edit: October 28, 2005, 03:41:57 PM by JaxWeather »
« Reply #2 on: October 28, 2005, 03:43:41 PM »
http://weatherstation.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IFRANKLI1&month=10&year=2005&day=29
working ok for me..
might be just wunderground is down or unreachable from where you are due to network issues
i.e i doubt its a bug with WD, often its something else, when it comes to things like this (after years of experience with these things)
Offline wreckdiver
  • Chuck
  • Elkton, Maryland USA
    • The Old Wesley School Weather Elkton, MD
« Reply #3 on: October 28, 2005, 04:04:29 PM »
Brain,
I'm having the same issue here, went back to 10.29y as a test that verision works. I'm getting the bad request error with 10.29z rev
Chuck
Dell XPS 3
XP Pro SP2
P4 3.6 Ghz
1 Gb Ram
Offline SandhurstWX
  • Ian
  • Another satisfied WD user!
  • Royal County of Berkshire, UK
    • Sandhurst Weather
« Reply #4 on: October 28, 2005, 04:06:17 PM »
I had noticed a problem also, version 29y seemed to send the data twice everytime (see http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=I90579247), and 29z rev wouldn't send the data at all. Now running 29s again and it seems to work ok  :?
I also found that it wasn't reporting the rain or wind gust data.
Update: 18:22, the wind gust updates ok with 29s, not raining here at the moment though!
« Last Edit: October 28, 2005, 04:22:34 PM by IanF »
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #5 on: October 28, 2005, 04:08:08 PM »
I went back to 10.29zz and it uploaded the data to WU on time at 1:00 PM ET.  Back to 10.29z rev now to see what happens at 1:15 PM ET...
Edit: 10.29z rev at 1:15 PM ET did not update WU, reverting to 10.29zz (but I still have the new climatedata files :) )
« Last Edit: October 28, 2005, 04:20:26 PM by JaxWeather »
Offline chucl1932
  • Tehachapi, California
    • Tehachapi(Golden Hills) California
« Reply #6 on: October 28, 2005, 04:52:04 PM »
WU did not upload with 29zrev, but when I went back to 29y it worked fine..
bug in 29z rev.
Chuck
« Reply #7 on: October 28, 2005, 05:27:19 PM »
and the ftpupd.exe version/file date is the same compared between the 2 versions?
so why is it working for me ok,and i dont remember changing anything..
« Reply #8 on: October 28, 2005, 05:29:52 PM »
mind you i am only on zz, trying z rev now
« Reply #9 on: October 28, 2005, 05:41:00 PM »
its ok for me, latest version, just did a test (clicked on test in the wunderground setup)
strange...
i am re uploading 10.29z rev full install now....
and lets see how that goes
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #10 on: October 28, 2005, 05:45:46 PM »
Brian,
When I was running 10.29z rev I tried the test button and still didn't get anything uploaded...
« Reply #11 on: October 28, 2005, 05:52:25 PM »
the only thing i worked on with the z rev from the zz version is the new noaa detailed stuff, and some other things (minor things that people have reported (like max gust from a metar if using a metar to update the data)
but a new memory chip has been causing my pc to crash randomly, and that has not helped...i have removed that now..
keep an eye out for the new 10.29z rev version....
« Reply #12 on: October 28, 2005, 05:53:57 PM »
actualy, that is availble here now:
http://www.weather-display.com/uploads/wdisplay32.exe
as it looks like the script to copy the files to the mirror servers is not working (I will have to contact florian about that)
Offline krunch2
  • Tom
    • Billings Weather
« Reply #13 on: October 28, 2005, 06:02:01 PM »
Brian, since I started this post, I will show my error message... Tom
**Start Time/date***:1:57:50 PM 10/28/2005
OKZ013.TXT
Permanent connection selected
Checking for what else to do...
there are 1 more things to do
Wunderground connected status: OK
Wunderground complete
Finshed email agenda
Finished email agenda, no ftp items to do...
Doing abort procedure/program close...
« Reply #14 on: October 28, 2005, 06:09:18 PM »
i see you have a forecast ftp download occuring at the same time...(i.e that file listed their)
what happens if you click on test in wd, in the wundeground setup?
is the version number (check file time and date) the same between the 2 versions of WD?
