I’m working on an 1-wire ultrasonic snow depth gauge based on the following link: http://voksenlia.net/met/snow.php
Dave at Springbok Electronics has been VERY helpful with a new 1-wire interface board that they just started to use. I’ll keep all you “Snow Lovers” updated on the progress. It basically provides a 0 - 5 vdc output based on the depth of the snow. I have the sensor already and am awaiting arrival of the interface board. We had our first snow here today - about 3/4 ".
I now have all the parts and hope to get it hooked up for testing this week. I see that Steinar has posted some more results of his recent testing with actual snowfalls. http://voksenlia.net/met/snow.php
By the look of it the really clever stuff is done in the data processing, it looks like Steinar uses some sort of “pre-processor” to smooth out the lumps and bumps (if you’ll excuse the pun).
Well I finally got it up and running of a sort. Still indoors while I’m doing the testing and calibration. I have the IButton viewer sensing both the temp and voltage from the A/D converter, but I can’t seem to get WD to read the A/D voltage. It sees the temp fine, but not the voltage. I have email in to Brian and I’ll keep you updated.
The big problem that seems to show up with the ultrasonic snow depth sensors is that they have trouble determining the depth of very dry fluffy snow. My sensor will be mounted much closer to the snow board than Steinar’s was so it will be interesting to see if that affect the sensitivity. Also Nafis in upstate NY has been working with both IR and Ultrasonic sensing so far and I understand is working on a laser measuring system now.
It’s just showing the 1-wire ROM ID’s under “VIEW” “WS2000 data report”.
Where should the ROM ID for the A/D be assigned in the 1-wire setup ??
The 1-wire setup does see the HUB A and the A/D ROM ID
This is not a priority, we’ll get it sorted out sooner or later, so no hurry. If I can provide any other info, please let me know.
OK, the Dallas 1 wire setup page shows the A/D sensor ROM ID, but when I paste it into the “Snow Depth Sensor” and “Save/Reset” the 1-wire setup the A/D sensor ROM ID is not allocated.
Yes, it is reading the Vad under the WS2000 data report fine ! Also the temp deg C and the Vdd voltage. Also reading under 1-wire setup “leaf wetness/soil mositure/snow sensor” page !! GREAT !!
Thanks !!
Any idea which graph it might show up on ?? I’ll try to get it moved outside tomorrow as we are expecting some snow this week.
