cloudy
Author Topic: Cloud height as reported by WD  (Read 2043 times)
Offline oldun
  • Rob.
  • S36° 50' 20" E174° 37' 32"
    • West Auckland Weather
« on: October 26, 2005, 01:46:54 AM »
I have some misgivings about the veracity of the cloud height as reported by WD it rarely agrees with the Meta from Auckland airport or visual evaluation, particularly under conditions of high humidity e.g. >60% Rel..
Would appreciate comments on this from others using this feature
WD running on Net Book, 1 Gb of ram, Windows 7 O.S. , La Crosse WS 2355 Weather Station, connected by USB. ,  ADSL. Internett connection.
 [WD ver. 10.37Q build 89.
Website:  http://www.weather-west.net/our_weather.html
Re: Cloud height as reported by WD
« Reply #1 on: October 26, 2005, 01:51:32 AM »
it relies on your weather stations humdiity and then dew point reading being correct, and then it assumes the environmental adiabatic elapse rate is standard, which it might not be, and its just as a guide as to where, if any, clouds will start forming at, but unstable conditions and a whole host of other factors means the actual cloud height will be different in practice...and so just use it as a guide....also have you set your stations altitude in the units setup?
Offline oldun
  • Rob.
« Reply #2 on: October 26, 2005, 01:56:40 AM »
Thanks for the info, yes the altitude is set at the height above MSL  ( from GPS data) of the main sensor (temp,hum,pressure) head of the weather station.
I'll put a note of explanation on my website.
Robert
« Reply #3 on: October 26, 2005, 01:58:04 AM »
mine currently says 3500 feet
and i would say at a guess the cloud BASE height is not too far from that, of the cumulus clouds
« Reply #4 on: October 26, 2005, 01:59:08 AM »
in fact the airport metar says cloudy with clear patches at 3500
so for me here, not all that far from you, WD is spot on!
Offline 41South
  • Colin
  • Strathmore, Wellington, NZ
    • 41south.net.nz
« Reply #5 on: October 26, 2005, 02:03:10 AM »
Brian,
Do you use the "standard" lapse rate, or the more correct wet/dry lapse rates?
Cheers, Colin.
Dallas 1-wire v3.0, Lightning, Humidity, Rain, Solar, Pressure, Temp sensors. Member of the Lightning Radar project.
Offline oldun
  • Rob.
« Reply #6 on: October 26, 2005, 02:14:28 AM »
Mine is currently showing 2077m whis is about 6814 feet a big difference
R
« Reply #7 on: October 26, 2005, 02:15:05 AM »
its a simple formula, but for me today, is surprisingly accurate
  temp:=((temperature-dewpoint)*412)+heightabovesealevel
for feet
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #8 on: October 26, 2005, 02:17:14 AM »
Robert
The cloud height is above MSL too.
« Reply #9 on: October 26, 2005, 02:18:12 AM »
as i said, its dependent on how accurate your dew point is
my dew point is 10.6oC, which ,matches exactly auckland airport, 18km from me in a straight line
my temperature is 20oC
« Reply #10 on: October 26, 2005, 02:19:43 AM »
checking your web site, your dew point is only 7.4oC, which is too low, and hence thats why the cloud base is being reported as too high
i have a davis VP, which is giving me real good dew point readings  :wink: :D
Offline 41South
  • Colin
    • 41south.net.nz
« Reply #11 on: October 26, 2005, 02:24:11 AM »
This calculator lines up pretty well with WD  :-)
http://www.csgnetwork.com/estcloudbasecalc.html
Cheers, Colin.
« Reply #12 on: October 26, 2005, 02:28:58 AM »
yes, if i put in my current numbers, and my height, 280 feet, then it matches wd (which is now saying 4100 feet )
Offline oldun
  • Rob.
« Reply #13 on: October 26, 2005, 05:04:10 PM »
Time 0700 wd reports cloud height 320 meters ( temp9.4C , dew point 7.0C Height ASL=21m)
Visual zero cloud, Auckland airport concurs.????????
Offline NorCal Dan
  • Dan - KJ6RGX
  • Truckee, California
    • Traveling RV Weather
« Reply #14 on: October 26, 2005, 06:01:16 PM »
The calculator gives me 313m for cloud height, matches up with your station report of 320m.
It doesn't mean there are clouds present, just that if there were clouds the expected base would be as reported.
