cloudy
Author Topic: Davis Rain Collector II  (Read 5261 times)
Offline sdietterle
  • Noblesville IN USA
    • http://www.dietterle.com
« on: December 30, 2002, 09:35:04 AM »
Can anyone tell me how I know if I have the unit that is .01 inch or .2mm.  The documentation has explanations for both but does not say how to determine which one it is.
I am using it with a 1-wire station and have made the conversion with the counter from AAG.  Each tip of the bucket gives a reading of .01 inches, so if I have that unit, great.  If it is the .2mm, is the a setting in WD to give correct readings in inches?
SteveD
Dallas 1-Wire V3 Station, 2 Dallas Temp/Humidity sensors, Davis rain guage (converted to 1-wire)
« Reply #1 on: January 02, 2003, 12:19:07 AM »
i have assumed 0.2mm gauge in wd
i will add opton to use the 0.254mm (i.e 0.01 inch) gauge instead
Offline grhughes
  • Huntsville,Alabama, USA
    • RuppWorld
I use the original
« Reply #2 on: January 02, 2003, 12:26:25 AM »
I use an original rain guage with my 1-wire setup.  Is there something I need to change?
-Rupp
WinXP
Davis VP
Offline sdietterle
« Reply #3 on: January 04, 2003, 12:52:13 AM »
My problem is that I can't find out which gauge I have.  I suppose i could put out a regular rain guage and compare the two.
SteveD
Offline aardvark
  • I am perfectly calm,ready to hear your opinion
  • Des Moines, Iowa, USA
    • Des Moines, Iowa Weather
the solution
« Reply #4 on: January 04, 2003, 01:37:00 AM »
If you purchased it within the US  it is 0.01 inches
VP2, Daytime Fars, Solar/UV; Soil station; extra temp/humid station; extra temp stations; Windows 7, 8G Ram , 1TB drive/external and Windows xp for weather data.
Offline sdietterle
« Reply #5 on: January 04, 2003, 12:10:22 PM »
Thanks, I assumed that was the case but...
SteveD
« Reply #6 on: January 04, 2003, 04:13:22 PM »
i am uploading vers 9.42a that has the option to use a 0.01 inch davis gauge added
Offline grhughes
    • RuppWorld
Brian
« Reply #7 on: January 04, 2003, 04:46:50 PM »
Does this effect all of us one wire users?  Do I need to be setting a value somewhere?  I use the original 1-wire rain guage.
-Rupp
WinXP
Davis VP
« Reply #8 on: January 04, 2003, 04:50:33 PM »
no greg
why would it?
its only uses the adjustment if you tick that box
if you have the original gauge, then it uses the default
thats it
simple
Offline grhughes
    • RuppWorld
Sorry Brain
« Reply #9 on: January 04, 2003, 06:04:08 PM »
Sorry to be so paranoid.  I thought it would get ticked by default as the new "standard" and thought I would need to change it for a different setting.  I finally found that option under set up one -wire weather station.
-Rupp
WinXP
Davis VP
